ProjeQtOr free project management software - ob_clean(); error when first installing ProjeQtOr - ProjeQtOr
25 Sep 2014 23:14 #1 by michaelmilette
After copying the projeqtor files in place on my webserver for the first time, I proceeded to access the new site. However as soon as I tried, I got the following error:
Notice: ob_clean() [<a href='ref.outcontrol'>ref.outcontrol</a>]: failed to delete buffer. No buffer to delete in /www/projeqtor/tool/projeqtor.php on line 6.
The solution is to simply replace the following on line 6 of tool/projeqtor.php::
Currently:
ob_clean();
Replace with:
if (ob_get_contents()) ob_end_clean();
It would be great if this modification could be incorporated into future versions of Projeqtor as it seems to work well since I made this change.
Best regards,
Michael Milette
25 Sep 2014 23:43 - 25 Sep 2014 23:44 #2 by babynus
The ob_clean has already been removed from V4.5.0.
The issue (some extra spaces after ?> tag) at the origin of the ob_clean() was identified and removed.
Anyway, thanks for your proposale.
Last edit: 25 Sep 2014 23:44 by babynus.
The following user(s) said Thank You: michaelmilette
