ProjeQtOr free project management software - Upgrade from 4.2.3 to 4.4.2 and a project and 4 activities are not visible. See attachments - ProjeQtOr
10 Nov 2014 18:04 #1 by IC_PRQA
Upgrade from 4.2.3 to 4.4.2 and a project and 4 items are not visible. See attachments
There are 4 items that are in the project that do not have a name associated with them.
I selected Planning and found 4 items without a name, namely, 368, 369, 370 and 389.
I selected number 369 and the Activity screen shows the name information.
These items do not appear in the Real Work Allocation
10 Nov 2014 18:35 #2 by babynus
Could you check in planningelement table lines wihr refType='Activity' and refId in (368, 369, 370, 389)
These lines should have been deleted with patch 4.3.2 including queries :
DELETE FROM `planningelement` WHERE refType = 'Activity' and not exists (select 'x' from `activity` where id=refId);
DELETE FROM `planningelement` WHERE refType = 'Milestone' and not exists (select 'x' from `milestone` where id=refId);
Could you try these requests again and report result ?
11 Nov 2014 08:55 #3 by ekolossov
Now these activities are gone completely and project still not visible
11 Nov 2014 23:47 #4 by babynus
Maybe you can try V4.5.0 newly deployed : it fixes some project acces issues.
12 Nov 2014 08:23 #5 by ekolossov
There is definitely problem with upgrade scripts. We have restored from backup to 4.2.3 and made an upgrade in 2 stages: first to 4.3.3 and after that to 4.4.2. This way everything is working properly. I hope in 4.5 you have fixed this problem
12 Nov 2014 09:56 #6 by climb4fun
Hi Ekolossov,
just let me mention at this point of time, I did upgrades from several old version to new versions and in addition I restored often old database dumps in new versions - no matter what version the dumps was drawn. I never have been faced with this kind of issues. Really strange your issues. :dry:
Klaus
The following user(s) said Thank You: IC_PRQA
