ProjeQtOr free project management software - Planning seems not working anymore after upgrading to 4.5.3 - Page 2 - ProjeQtOr
08 Jan 2015 11:10 #7 by jphuart
I'm doing this as user that has admin privileges on all projects.
I'll keep in mind the access rights, because it's strange that there are no error messages issued.
08 Jan 2015 18:34 - 08 Jan 2015 18:36 #8 by jphuart
thanks for the remarks, I've found where was the problem, or at least part of it.
I have created "internal" projects for each of my clients so I can easily edit my invoices for each of them at the end of the month.
Then I have "time & materials" subprojects of these "internal" projects and I create activities inside these subprojects.
Until now I was declaring rates of affectation of resources only for the subprojects, while they were at 0% for my "internal" parent projects. Until now this was working fine, but for the last upgrade the calculation of planned work was providing a null result. Just giving a proper rate to affectation for the parent projects has solved the problem. Now planned work seems to be correctly calculated again.
Any suggestion to better understand such behaviour is welcome.
Ciao
Jean Pierre
Last edit: 08 Jan 2015 18:36 by jphuart. Reason: simplify explanation
08 Jan 2015 18:59 #9 by babynus
You put the finger on the correct origin of the issue.
In V4.5, the affectation rate determination has changed because it now takes into account start and end dates of affectations.
The fact is that % rate is a limitation that is controlled on sub-project and top-projects.
So, the applied affectation rate limit on each sub-project cannot be more that rate on top project.
So, having rate of 0% should have brought the issue on previous versions, but this was possibly a bug that new functionality fixed.
The following user(s) said Thank You: jphuart
16 Jan 2015 02:56 #10 by udirect61
Planning calculation is done in /model/PlannedWork.php, method plan().
And it works fine.
