ProjeQtOr free project management software - install problem~ help me - ProjeQtOr
11 Jun 2015 02:59 #1 by mediassu
use mysql 5.x, iis 7, php 5.x
not login in...
2015-06-11 02:40:39 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2015-06-11 02:40:39 ***** ERROR ***** For query : select * from parameter where (idUser is null and idProject is null)
2015-06-11 02:40:39 ***** ERROR ***** Strack trace :
2015-06-11 02:40:39 ***** ERROR ***** #0 Sql->query called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1517]
2015-06-11 02:40:39 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\projeqtor\model\Parameter.php:572]
2015-06-11 02:40:39 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [C:\inetpub\wwwroot\projeqtor\view\login.php:55]
2015-06-11 02:40:39 ***** ERROR ***** #3 include called at [C:\inetpub\wwwroot\projeqtor\tool\projeqtor.php:162]
2015-06-11 02:40:39 ***** ERROR ***** #4 require_once called at [C:\inetpub\wwwroot\projeqtor\view\main.php:36]
2015-06-11 02:40:39 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [C:\inetpub\wwwroot\projeqtor\view\login.php:138]
2015-06-11 02:40:39 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [C:\inetpub\wwwroot\projeqtor\view\login.php:159]
2015-06-11 02:40:39 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [C:\inetpub\wwwroot\projeqtor\view\login.php:186]
2015-06-11 02:40:39 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [C:\inetpub\wwwroot\projeqtor\view\login.php:192]
2015-06-11 02:40:43 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.parameter' doesn't exist
2015-06-11 02:40:43 ***** ERROR ***** For query : select * from parameter where (idUser is null and idProject is null)
2015-06-11 02:40:43 ***** ERROR ***** Strack trace :
2015-06-11 02:40:43 ***** ERROR ***** #0 Sql->query called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1517]
2015-06-11 02:40:43 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\projeqtor\model\Parameter.php:572]
2015-06-11 02:40:43 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [C:\inetpub\wwwroot\projeqtor\model\User.php:122]
2015-06-11 02:40:43 ***** ERROR ***** #3 User->__construct called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1650]
2015-06-11 02:40:43 ***** ERROR ***** #4 SqlElement->getSingleSqlElementFromCriteria called at [C:\inetpub\wwwroot\projeqtor\tool\getHash.php:39]
2015-06-11 02:40:43 ***** ERROR ***** #2 Parameter->getGlobalParameter called at [C:\inetpub\wwwroot\projeqtor\model\User.php:127]
2015-06-11 02:40:43 ***** ERROR ***** #3 User->__construct called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1477]
2015-06-11 02:40:43 ***** ERROR ***** #4 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1658]
2015-06-11 02:40:43 ***** ERROR ***** #5 SqlElement->getSingleSqlElementFromCriteria called at [C:\inetpub\wwwroot\projeqtor\tool\getHash.php:39]
2015-06-11 02:40:43 ***** ERROR ***** #3 User->__construct called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:2185]
2015-06-11 02:40:43 ***** ERROR ***** #4 SqlElement->getFormatList called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1952]
2015-06-11 02:40:43 ***** ERROR ***** #5 SqlElement->getDataType called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1484]
2015-06-11 02:40:43 ***** ERROR ***** #6 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1658]
2015-06-11 02:40:43 ***** ERROR ***** #7 SqlElement->getSingleSqlElementFromCriteria called at [C:\inetpub\wwwroot\projeqtor\tool\getHash.php:39]
2015-06-11 02:40:43 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.resource' doesn't exist
2015-06-11 02:40:43 ***** ERROR ***** For query : desc resource
2015-06-11 02:40:43 ***** ERROR ***** #0 Sql->query called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:2195]
2015-06-11 02:40:43 ***** ERROR ***** #1 SqlElement->getFormatList called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1952]
2015-06-11 02:40:43 ***** ERROR ***** #2 SqlElement->getDataType called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1484]
2015-06-11 02:40:43 ***** ERROR ***** #3 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1658]
2015-06-11 02:40:43 ***** ERROR ***** For query : select * from resource where resource.name='admin' and resource.isUser = '1'
2015-06-11 02:40:43 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1658]
2015-06-11 02:40:43 ***** ERROR ***** #2 SqlElement->getSingleSqlElementFromCriteria called at [C:\inetpub\wwwroot\projeqtor\tool\getHash.php:39]
2015-06-11 02:40:43 ===== TRACE =====
2015-06-11 02:40:43 ===== TRACE ===== =====================================
2015-06-11 02:40:43 ===== TRACE ===== DataBase actual Version =
2015-06-11 02:40:43 ===== TRACE ===== ProjeQtOr actual Version = V4.5.6
2015-06-11 02:40:43 ===== TRACE ===== VERSION V0.3.0
2015-06-11 02:40:43 ===== TRACE ===== Table "accessprofile" created.
2015-06-11 02:40:43 ===== TRACE ===== 9 lines inserted into table "accessprofile".
2015-06-11 02:40:43 ===== TRACE ===== Table "accessright" created.
2015-06-11 02:40:43 ===== TRACE ===== 56 lines inserted into table "accessright".
2015-06-11 02:40:43 ===== TRACE ===== Table "accessscope" created.
2015-06-11 02:40:43 ===== TRACE ===== 4 lines inserted into table "accessscope".
2015-06-11 02:40:43 ===== TRACE ===== Table "action" created.
2015-06-11 02:40:43 ===== TRACE ===== Table "activity" created.
2015-06-11 02:40:43 ===== TRACE ===== Table "affectation" created.
2015-06-11 02:40:43 ===== TRACE ===== Table "attachement" created.
2015-06-11 02:40:43 ===== TRACE ===== Table "client" created.
2015-06-11 02:40:43 ===== TRACE ===== Table "criticality" created.
2015-06-11 02:40:43 ===== TRACE ===== 4 lines inserted into table "criticality".
2015-06-11 02:40:43 ===== TRACE ===== Table "habilitation" created.
2015-06-11 02:40:43 ===== TRACE ===== 343 lines inserted into table "habilitation".
2015-06-11 02:40:44 ===== TRACE ===== Table "history" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "issue" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "likelihood" created.
2015-06-11 02:40:44 ===== TRACE ===== 3 lines inserted into table "likelihood".
2015-06-11 02:40:44 ===== TRACE ===== Table "menu" created.
2015-06-11 02:40:44 ===== TRACE ===== 45 lines inserted into table "menu".
2015-06-11 02:40:44 ===== TRACE ===== Table "message" created.
2015-06-11 02:40:44 ===== TRACE ===== 1 lines inserted into table "message".
2015-06-11 02:40:44 ===== TRACE ===== Table "milestone" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "note" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "parameter" created.
2015-06-11 02:40:44 ===== TRACE ===== 17 lines inserted into table "parameter".
2015-06-11 02:40:44 ===== TRACE ===== Table "planningelement" created.
2015-06-11 02:40:44 ===== TRACE ===== Index "planningelementTopId" created.
2015-06-11 02:40:44 ===== TRACE ===== Index "planningelementRef" created.
2015-06-11 02:40:44 ===== TRACE ===== Index "planningelementTopRef" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "priority" created.
2015-06-11 02:40:44 ===== TRACE ===== 4 lines inserted into table "priority".
2015-06-11 02:40:44 ===== TRACE ===== Table "profile" created.
2015-06-11 02:40:44 ===== TRACE ===== 7 lines inserted into table "profile".
2015-06-11 02:40:44 ===== TRACE ===== Table "project" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "risk" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "severity" created.
2015-06-11 02:40:44 ===== TRACE ===== 3 lines inserted into table "severity".
2015-06-11 02:40:44 ===== TRACE ===== Table "sla" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "status" created.
2015-06-11 02:40:44 ===== TRACE ===== 12 lines inserted into table "status".
2015-06-11 02:40:44 ===== TRACE ===== Table "task" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "ticket" created.
2015-06-11 02:40:44 ===== TRACE ===== Table "type" created.
2015-06-11 02:40:44 ===== TRACE ===== 24 lines inserted into table "type".
2015-06-11 02:40:44 ===== TRACE ===== Table "urgency" created.
2015-06-11 02:40:44 ===== TRACE ===== 3 lines inserted into table "urgency".
2015-06-11 02:40:44 ===== TRACE ===== Table "resource" created.
2015-06-11 02:40:44 ===== TRACE ===== 2 lines inserted into table "resource".
2015-06-11 02:40:44 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:44 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:44 ===== TRACE ===== =====================================
2015-06-11 02:40:44 ===== TRACE ===== VERSION V0.4.0
2015-06-11 02:40:45 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:40:45 ===== TRACE ===== Table "team" created.
2015-06-11 02:40:45 ===== TRACE ===== Table "menu" truncated.
2015-06-11 02:40:45 ===== TRACE ===== 46 lines inserted into table "menu".
2015-06-11 02:40:45 ===== TRACE ===== Table "accessright" truncated.
2015-06-11 02:40:45 ===== TRACE ===== 63 lines inserted into table "accessright".
2015-06-11 02:40:45 ===== TRACE ===== Table "habilitation" truncated.
2015-06-11 02:40:45 ===== TRACE ===== 350 lines inserted into table "habilitation".
2015-06-11 02:40:45 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:45 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:45 ===== TRACE ===== =====================================
2015-06-11 02:40:45 ===== TRACE ===== VERSION V0.5.0
2015-06-11 02:40:45 ===== TRACE ===== Table "link" created.
2015-06-11 02:40:45 ===== TRACE ===== Table "linkable" created.
2015-06-11 02:40:45 ===== TRACE ===== Table "activity" altered.
2015-06-11 02:40:45 ===== TRACE ===== Table "ticket" altered.
2015-06-11 02:40:45 ===== TRACE ===== Table "milestone" altered.
2015-06-11 02:40:45 ===== TRACE ===== 3 lines inserted into table "linkable".
2015-06-11 02:40:45 ===== TRACE ===== VERSION V0.6.0
2015-06-11 02:40:45 ===== TRACE ===== Table "assignment" created.
2015-06-11 02:40:45 ===== TRACE ===== Table "task" dropped.
2015-06-11 02:40:45 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:40:45 ===== TRACE ===== 1 lines inserted into table "type".
2015-06-11 02:40:45 ===== TRACE ===== Table "project" altered.
2015-06-11 02:40:45 ===== TRACE ===== Index "accessrightProfile" created.
2015-06-11 02:40:45 ===== TRACE ===== Index "" created.
2015-06-11 02:40:45 ===== TRACE ===== Index "actionProject" created.
2015-06-11 02:40:45 ===== TRACE ===== Index "actionUser" created.
2015-06-11 02:40:45 ===== TRACE ===== Index "actionResource" created.
2015-06-11 02:40:45 ===== TRACE ===== Index "actionStatus" created.
2015-06-11 02:40:45 ===== TRACE ===== Index "activityProject" created.
2015-06-11 02:40:45 ===== TRACE ===== Index "activityUser" created.
2015-06-11 02:40:45 ===== TRACE ===== Index "activityResource" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "activityStatus" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "activityType" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "activityActivity" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "affectationProject" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "affectationResource" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "assignmentProject" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "assignmentResource" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "assignmentRef" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "attachementUser" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "attachementRef" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "habilitationProfile" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "habilitationMenu" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "historyUser" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "historyRef" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "issueProject" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "issueUser" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "issueResource" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "issueStatus" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "issueType" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "linkRef1" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "linkRef2" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "menuMenu" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "messageProject" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "messageUser" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "messageType" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "messageProfile" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "milestoneProject" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "milestoneUser" created.
2015-06-11 02:40:46 ===== TRACE ===== Index "milestoneResource" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "milestoneStatus" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "milestoneType" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "milestoneActivity" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "noteUser" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "noteRef" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "parameterProject" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "parameterUser" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "planningelementProject" created.
2015-06-11 02:40:47 ***** ERROR ***** Exception-[42000] SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 767 bytes
2015-06-11 02:40:47 ***** ERROR ***** For query : CREATE INDEX planningelementWbsSortable ON `planningelement` (`wbsSortable`);
2015-06-11 02:40:47 ***** ERROR ***** Strack trace :
2015-06-11 02:40:47 ***** ERROR ***** #0 Sql->query called at [C:\inetpub\wwwroot\projeqtor\db\maintenanceFunctions.php:65]
2015-06-11 02:40:47 ***** ERROR ***** #1 runScript called at [C:\inetpub\wwwroot\projeqtor\db\maintenance.php:94]
2015-06-11 02:40:47 ***** ERROR ***** #2 include called at [C:\inetpub\wwwroot\projeqtor\tool\loginCheck.php:52]
2015-06-11 02:40:47 ===== TRACE ===== Error # 1 => SQL error while executing maintenance query for version V0.6.0 (see above message)
2015-06-11 02:40:47 ===== TRACE ===== *************************************************
2015-06-11 02:40:47 ===== TRACE ===== Index "projectProject" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "projectClient" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "riskProject" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "riskUser" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "riskResource" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "riskStatus" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "riskType" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "ticketProject" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "ticketUser" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "ticketResource" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "ticketStatus" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "ticketType" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "ticketActivity" created.
2015-06-11 02:40:47 ===== TRACE ===== Table "work" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "workDay" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "workWeek" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "workMonth" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "workYear" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "workRef" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "workResource" created.
2015-06-11 02:40:47 ===== TRACE ===== Index "workAssignment" created.
2015-06-11 02:40:47 ===== TRACE ===== 1 lines updated into table "menu".
2015-06-11 02:40:47 ===== TRACE ===== 7 lines updated into table "habilitation".
2015-06-11 02:40:47 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:47 ===== TRACE ===== WITH 1 ERROR
2015-06-11 02:40:47 ===== TRACE ===== =====================================
2015-06-11 02:40:47 ===== TRACE ===== VERSION V0.7.0
2015-06-11 02:40:48 ===== TRACE ===== Table "plannedwork" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "plannedworkDay" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "plannedworkWeek" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "plannedworkMonth" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "plannedworkYear" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "plannedworkRef" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "plannedworkResource" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "plannedworkAssignment" created.
2015-06-11 02:40:48 ===== TRACE ===== Table "assignment" altered.
2015-06-11 02:40:48 ===== TRACE ===== Table "dependency" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "dependencyPredecessorRef" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "dependencyPredecessorId" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "dependencySuccessorRef" created.
2015-06-11 02:40:48 ===== TRACE ===== Index "dependencySuccessorId" created.
2015-06-11 02:40:48 ===== TRACE ===== Table "dependable" created.
2015-06-11 02:40:48 ===== TRACE ===== 3 lines inserted into table "dependable".
2015-06-11 02:40:48 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:40:48 ===== TRACE ===== Index "planningElementDependencyLevel" created.
2015-06-11 02:40:48 ===== TRACE ===== 0 lines updated into table "planningelement".
2015-06-11 02:40:48 ===== TRACE ===== Table "ticket" altered.
2015-06-11 02:40:48 ===== TRACE ===== Table "criticality" truncated.
2015-06-11 02:40:48 ===== TRACE ===== 4 lines inserted into table "criticality".
2015-06-11 02:40:48 ===== TRACE ===== Table "likelihood" truncated.
2015-06-11 02:40:48 ===== TRACE ===== 3 lines inserted into table "likelihood".
2015-06-11 02:40:48 ===== TRACE ===== Table "priority" truncated.
2015-06-11 02:40:48 ===== TRACE ===== 4 lines inserted into table "priority".
2015-06-11 02:40:48 ===== TRACE ===== Table "severity" truncated.
2015-06-11 02:40:48 ===== TRACE ===== 3 lines inserted into table "severity".
2015-06-11 02:40:48 ===== TRACE ===== Table "urgency" truncated.
2015-06-11 02:40:48 ===== TRACE ===== 3 lines inserted into table "urgency".
2015-06-11 02:40:48 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:40:48 ===== TRACE ===== 7 lines inserted into table "habilitation".
2015-06-11 02:40:48 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:48 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:48 ===== TRACE ===== =====================================
2015-06-11 02:40:48 ===== TRACE ===== VERSION V0.8.0
2015-06-11 02:40:49 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "planningmode" created.
2015-06-11 02:40:49 ===== TRACE ===== 6 lines inserted into table "planningmode".
2015-06-11 02:40:49 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "ticket" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "activity" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "milestone" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "risk" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "action" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "project" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "issue" altered.
2015-06-11 02:40:49 ===== TRACE ===== Table "status" altered.
2015-06-11 02:40:50 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:40:50 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:50 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:50 ===== TRACE ===== =====================================
2015-06-11 02:40:50 ===== TRACE ===== VERSION V0.9.0
2015-06-11 02:40:50 ===== TRACE ===== Table "workflow" dropped.
2015-06-11 02:40:50 ===== TRACE ===== Table "workflow" created.
2015-06-11 02:40:50 ===== TRACE ===== Table "workflowstatus" dropped.
2015-06-11 02:40:50 ===== TRACE ===== Table "workflowstatus" created.
2015-06-11 02:40:50 ===== TRACE ===== 0 lines deleted from table "menu".
2015-06-11 02:40:50 ===== TRACE ===== 2 lines inserted into table "menu".
2015-06-11 02:40:50 ===== TRACE ===== 2 lines inserted into table "habilitation".
2015-06-11 02:40:50 ===== TRACE ===== Table "type" altered.
2015-06-11 02:40:50 ===== TRACE ===== Table "action" altered.
2015-06-11 02:40:50 ===== TRACE ===== 3 lines inserted into table "type".
2015-06-11 02:40:50 ===== TRACE ===== 4 lines inserted into table "workflow".
2015-06-11 02:40:50 ===== TRACE ===== 503 lines inserted into table "workflowstatus".
2015-06-11 02:40:50 ===== TRACE ===== 28 lines updated into table "type".
2015-06-11 02:40:50 ===== TRACE ===== VERSION V1.0.0
2015-06-11 02:40:50 ===== TRACE ===== Table "assignment" altered.
2015-06-11 02:40:50 ===== TRACE ===== Table "filter" created.
2015-06-11 02:40:50 ===== TRACE ===== Table "filtercriteria" created.
2015-06-11 02:40:50 ===== TRACE ===== VERSION V1.1.0
2015-06-11 02:40:50 ===== TRACE ===== Table "report" created.
2015-06-11 02:40:50 ===== TRACE ===== Table "reportparameter" created.
2015-06-11 02:40:50 ===== TRACE ===== Table "reportcategory" created.
2015-06-11 02:40:50 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:40:50 ===== TRACE ===== 3 lines inserted into table "habilitation".
2015-06-11 02:40:50 ===== TRACE ===== 2 lines inserted into table "reportcategory".
2015-06-11 02:40:50 ===== TRACE ===== 6 lines inserted into table "report".
2015-06-11 02:40:50 ===== TRACE ===== 6 lines inserted into table "reportparameter".
2015-06-11 02:40:50 ===== TRACE ===== VERSION V1.2.0
2015-06-11 02:40:50 ===== TRACE ===== Table "reportparameter" altered.
2015-06-11 02:40:50 ===== TRACE ===== 1 lines inserted into table "report".
2015-06-11 02:40:50 ===== TRACE ===== 1 lines updated into table "reportparameter".
2015-06-11 02:40:50 ===== TRACE ===== 4 lines updated into table "reportparameter".
2015-06-11 02:40:50 ===== TRACE ===== 4 lines inserted into table "reportparameter".
2015-06-11 02:40:50 ===== TRACE ===== Table "decision" created.
2015-06-11 02:40:50 ===== TRACE ===== Table "question" created.
2015-06-11 02:40:50 ===== TRACE ===== Table "meeting" created.
2015-06-11 02:40:50 ===== TRACE ===== 1 lines updated into table "menu".
2015-06-11 02:40:50 ===== TRACE ===== 8 lines inserted into table "menu".
2015-06-11 02:40:50 ===== TRACE ===== 28 lines inserted into table "accessright".
2015-06-11 02:40:50 ===== TRACE ===== 56 lines inserted into table "habilitation".
2015-06-11 02:40:50 ===== TRACE ===== 7 lines updated into table "habilitation".
2015-06-11 02:40:50 ===== TRACE ===== 1 lines updated into table "habilitation".
2015-06-11 02:40:50 ===== TRACE ===== 9 lines inserted into table "type".
2015-06-11 02:40:50 ===== TRACE ===== 3 lines inserted into table "linkable".
2015-06-11 02:40:50 ===== TRACE ===== 1 lines inserted into table "status".
2015-06-11 02:40:50 ===== TRACE ===== 3 lines inserted into table "workflow".
2015-06-11 02:40:50 ===== TRACE ===== 21 lines deleted from table "workflowstatus".
2015-06-11 02:40:50 ===== TRACE ===== 144 lines inserted into table "workflowstatus".
2015-06-11 02:40:50 ===== TRACE ===== Table "mailable" created.
2015-06-11 02:40:50 ===== TRACE ===== 9 lines inserted into table "mailable".
2015-06-11 02:40:51 ===== TRACE ===== Table "statusmail" created.
2015-06-11 02:40:51 ===== TRACE ===== 63 lines inserted into table "statusmail".
2015-06-11 02:40:51 ===== TRACE ===== Table "mail" created.
2015-06-11 02:40:51 ===== TRACE ===== Table "assignment" altered.
2015-06-11 02:40:51 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:51 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:51 ===== TRACE ===== =====================================
2015-06-11 02:40:51 ===== TRACE ===== VERSION V1.3.0
2015-06-11 02:40:51 ===== TRACE ===== 1 lines inserted into table "report".
2015-06-11 02:40:51 ===== TRACE ===== 1 lines inserted into table "reportparameter".
2015-06-11 02:40:51 ===== TRACE ===== Index "actionType" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "decisionProject" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "decisionType" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "decisionUser" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "decisionResource" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "decisionStatus" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "filterUser" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "filtercriteriaFilter" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "issuePriority" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "mailProject" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "mailUser" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "mailRef" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "mailStatus" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "meetingProject" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "meetingType" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "meetingUser" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "meetingResource" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "meetingStatus" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "planningelementPlanningMode" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "projectUser" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "questionProject" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "questionType" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "questionUser" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "questionResource" created.
2015-06-11 02:40:51 ===== TRACE ===== Index "questionStatus" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "reportReportCategory" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "reportparameterReport" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "riskSeverity" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "riskLikelihood" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "riskCriticality" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "statusmailStatus" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "statusmailMailable" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "ticketUrgency" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "ticketPriority" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "ticketCriticality" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "typeScope" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "userProfile" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "userTeam" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "workflowstatusProfile" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "workflowstatusWorkflow" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "workflowstatusStatusFrom" created.
2015-06-11 02:40:52 ===== TRACE ===== Index "workflowstatusStatusTo" created.
2015-06-11 02:40:52 ===== TRACE ===== 1 lines inserted into table "reportcategory".
2015-06-11 02:40:52 ===== TRACE ===== 1 lines inserted into table "report".
2015-06-11 02:40:52 ===== TRACE ===== 5 lines inserted into table "reportparameter".
2015-06-11 02:40:52 ===== TRACE ===== 4 lines inserted into table "reportparameter".
2015-06-11 02:40:52 ===== TRACE ===== 6 lines inserted into table "report".
2015-06-11 02:40:52 ===== TRACE ===== 24 lines inserted into table "reportparameter".
2015-06-11 02:40:52 ===== TRACE ===== 1 lines updated into table "priority".
2015-06-11 02:40:52 ===== TRACE ===== 2 lines inserted into table "report".
2015-06-11 02:40:52 ===== TRACE ===== 6 lines inserted into table "reportparameter".
2015-06-11 02:40:52 ===== TRACE ===== 1 lines updated into table "report".
2015-06-11 02:40:52 ===== TRACE ===== 2 lines inserted into table "reportcategory".
2015-06-11 02:40:52 ===== TRACE ===== 7 lines inserted into table "report".
2015-06-11 02:40:52 ===== TRACE ===== 11 lines inserted into table "reportparameter".
2015-06-11 02:40:52 ===== TRACE ===== Table "type" altered.
2015-06-11 02:40:52 ===== TRACE ===== 37 lines updated into table "".
2015-06-11 02:40:52 ===== TRACE ===== Table "status" altered.
2015-06-11 02:40:52 ===== TRACE ===== 9 lines updated into table "status".
2015-06-11 02:40:52 ===== TRACE ===== 6 lines updated into table "status".
2015-06-11 02:40:52 ===== TRACE ===== Table "workflow" altered.
2015-06-11 02:40:52 ===== TRACE ===== 37 lines updated into table "type".
2015-06-11 02:40:53 ===== TRACE ===== Table "ticket" altered.
2015-06-11 02:40:53 ===== TRACE ===== Table "activity" altered.
2015-06-11 02:40:53 ===== TRACE ===== Table "milestone" altered.
2015-06-11 02:40:53 ===== TRACE ===== Table "risk" altered.
2015-06-11 02:40:53 ===== TRACE ===== Table "action" altered.
2015-06-11 02:40:53 ===== TRACE ===== Table "issue" altered.
2015-06-11 02:40:53 ===== TRACE ===== Table "question" altered.
2015-06-11 02:40:53 ===== TRACE ===== Table "meeting" altered.
2015-06-11 02:40:53 ===== TRACE ===== 0 lines updated into table "ticket".
2015-06-11 02:40:53 ===== TRACE ===== 0 lines updated into table "activity".
2015-06-11 02:40:53 ===== TRACE ===== 0 lines updated into table "milestone".
2015-06-11 02:40:53 ===== TRACE ===== 0 lines updated into table "risk".
2015-06-11 02:40:53 ===== TRACE ===== 0 lines updated into table "action".
2015-06-11 02:40:53 ===== TRACE ===== 0 lines updated into table "issue".
2015-06-11 02:40:53 ===== TRACE ===== 0 lines updated into table "question".
2015-06-11 02:40:53 ===== TRACE ===== Table "habilitationreport" created.
2015-06-11 02:40:53 ===== TRACE ===== Index "habilitationReportProfile" created.
2015-06-11 02:40:53 ===== TRACE ===== Index "habilitationReportReport" created.
2015-06-11 02:40:53 ===== TRACE ===== Table "habilitationother" created.
2015-06-11 02:40:53 ===== TRACE ===== 2 lines inserted into table "menu".
2015-06-11 02:40:53 ===== TRACE ===== 12 lines inserted into table "habilitation".
2015-06-11 02:40:53 ===== TRACE ===== 71 lines inserted into table "habilitationreport".
2015-06-11 02:40:53 ===== TRACE ===== 25 lines updated into table "report".
2015-06-11 02:40:53 ===== TRACE ===== 7 lines inserted into table "habilitationother".
2015-06-11 02:40:53 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:53 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:53 ===== TRACE ===== =====================================
2015-06-11 02:40:53 ===== TRACE ===== VERSION V1.4.0
2015-06-11 02:40:54 ===== TRACE ===== Table "planningmode" altered.
2015-06-11 02:40:54 ===== TRACE ===== 2 lines inserted into table "planningmode".
2015-06-11 02:40:54 ===== TRACE ===== 0 lines updated into table "planningelement".
2015-06-11 02:40:54 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:40:54 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:40:54 ===== TRACE ===== 1 lines inserted into table "habilitation".
2015-06-11 02:40:54 ===== TRACE ===== Table "issue" altered.
2015-06-11 02:40:54 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:54 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:54 ===== TRACE ===== =====================================
2015-06-11 02:40:54 ===== TRACE ===== VERSION V1.5.0
2015-06-11 02:40:54 ===== TRACE ===== Table "affectation" altered.
2015-06-11 02:40:54 ===== TRACE ===== Table "assignment" altered.
2015-06-11 02:40:54 ===== TRACE ===== Table "work" altered.
2015-06-11 02:40:54 ===== TRACE ===== Table "plannedwork" altered.
2015-06-11 02:40:54 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:40:54 ===== TRACE ===== 0 lines updated into table "type".
2015-06-11 02:40:54 ===== TRACE ===== Table "resourcecost" created.
2015-06-11 02:40:54 ===== TRACE ===== Table "role" created.
2015-06-11 02:40:54 ===== TRACE ===== 5 lines inserted into table "role".
2015-06-11 02:40:54 ===== TRACE ===== Table "visibilityscope" created.
2015-06-11 02:40:54 ===== TRACE ===== 3 lines inserted into table "visibilityscope".
2015-06-11 02:40:54 ===== TRACE ===== 14 lines inserted into table "habilitationother".
2015-06-11 02:40:55 ===== TRACE ===== Table "ticket" altered.
2015-06-11 02:40:55 ===== TRACE ===== 1 lines inserted into table "reportcategory".
2015-06-11 02:40:55 ===== TRACE ===== 2 lines inserted into table "report".
2015-06-11 02:40:55 ===== TRACE ===== 2 lines inserted into table "reportparameter".
2015-06-11 02:40:55 ===== TRACE ===== 6 lines inserted into table "habilitationreport".
2015-06-11 02:40:55 ===== TRACE ===== 3 lines inserted into table "report".
2015-06-11 02:40:55 ===== TRACE ===== 3 lines inserted into table "reportparameter".
2015-06-11 02:40:55 ===== TRACE ===== 9 lines inserted into table "habilitationreport".
2015-06-11 02:40:55 ===== TRACE ===== Table "statusmail" altered.
2015-06-11 02:40:55 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:55 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:55 ===== TRACE ===== =====================================
2015-06-11 02:40:55 ===== TRACE ===== VERSION V1.6.0
2015-06-11 02:40:55 ===== TRACE ===== Table "work" altered.
2015-06-11 02:40:55 ===== TRACE ===== Table "list" created.
2015-06-11 02:40:55 ===== TRACE ===== 2 lines inserted into table "list".
2015-06-11 02:40:55 ===== TRACE ===== 7 lines inserted into table "habilitationother".
2015-06-11 02:40:55 ===== TRACE ===== Table "expense" created.
2015-06-11 02:40:55 ===== TRACE ===== Table "expensedetail" created.
2015-06-11 02:40:55 ===== TRACE ===== Table "expensedetailtype" created.
2015-06-11 02:40:55 ===== TRACE ===== 1 lines updated into table "menu".
2015-06-11 02:40:55 ===== TRACE ===== 10 lines inserted into table "menu".
2015-06-11 02:40:55 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:40:55 ===== TRACE ===== 27 lines inserted into table "habilitation".
2015-06-11 02:40:55 ===== TRACE ===== 2 lines inserted into table "habilitation".
2015-06-11 02:40:55 ===== TRACE ===== 28 lines inserted into table "accessright".
2015-06-11 02:40:55 ===== TRACE ===== 0 lines deleted from table "type".
2015-06-11 02:40:55 ===== TRACE ===== 9 lines inserted into table "type".
2015-06-11 02:40:55 ===== TRACE ===== 1 lines inserted into table "workflow".
2015-06-11 02:40:55 ===== TRACE ===== 17 lines inserted into table "workflowstatus".
2015-06-11 02:40:55 ===== TRACE ===== 4 lines inserted into table "expensedetailtype".
2015-06-11 02:40:55 ===== TRACE ===== 6 lines inserted into table "report".
2015-06-11 02:40:55 ===== TRACE ===== 8 lines inserted into table "reportparameter".
2015-06-11 02:40:55 ===== TRACE ===== 18 lines inserted into table "habilitationreport".
2015-06-11 02:40:55 ===== TRACE ===== Table "meeting" altered.
2015-06-11 02:40:55 ===== TRACE ===== 10 lines inserted into table "reportparameter".
2015-06-11 02:40:55 ===== TRACE ===== VERSION V1.7.0
2015-06-11 02:40:55 ===== TRACE ===== Index "expenseProject" created.
2015-06-11 02:40:55 ===== TRACE ===== Index "expenseType" created.
2015-06-11 02:40:55 ===== TRACE ===== Index "expenseUser" created.
2015-06-11 02:40:55 ===== TRACE ===== Index "expenseResource" created.
2015-06-11 02:40:55 ===== TRACE ===== Index "expenseStatus" created.
2015-06-11 02:40:55 ===== TRACE ===== Index "expenseDay" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "expenseWeek" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "expenseMonth" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "expenseYear" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "expensedetailProject" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "expensedetailExpenseDetailType" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "expensedetailExpense" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "habilitationotherProfile" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "listList" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "planningmodeApplyTo" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "resourcecostResource" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "userIsResource" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "userIsUser" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "userIsContact" created.
2015-06-11 02:40:56 ===== TRACE ===== Table "calendar" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "calendarDay" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "calendarWeek" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "calendarMonth" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "calendarYear" created.
2015-06-11 02:40:56 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:40:56 ===== TRACE ===== 3 lines inserted into table "habilitation".
2015-06-11 02:40:56 ===== TRACE ===== Table "origin" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "originOrigin" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "originRef" created.
2015-06-11 02:40:56 ===== TRACE ===== Table "originable" created.
2015-06-11 02:40:56 ===== TRACE ===== 11 lines inserted into table "originable".
2015-06-11 02:40:56 ===== TRACE ===== Table "copyable" created.
2015-06-11 02:40:56 ===== TRACE ===== 11 lines inserted into table "copyable".
2015-06-11 02:40:56 ===== TRACE ===== Table "product" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "productClient" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "pruductContact" created.
2015-06-11 02:40:56 ===== TRACE ===== Table "version" created.
2015-06-11 02:40:56 ===== TRACE ===== Index "versionProduct" created.
2015-06-11 02:40:57 ===== TRACE ===== Index "versionContact" created.
2015-06-11 02:40:57 ===== TRACE ===== Index "versionResource" created.
2015-06-11 02:40:57 ===== TRACE ===== Table "versionproject" created.
2015-06-11 02:40:57 ===== TRACE ===== Index "versionprojectProject" created.
2015-06-11 02:40:57 ===== TRACE ===== Index "versionprojectVersion" created.
2015-06-11 02:40:57 ===== TRACE ===== 2 lines inserted into table "menu".
2015-06-11 02:40:57 ===== TRACE ===== 6 lines inserted into table "habilitation".
2015-06-11 02:40:57 ===== TRACE ===== Table "project" altered.
2015-06-11 02:40:57 ===== TRACE ===== Index "projectContact" created.
2015-06-11 02:40:57 ===== TRACE ===== Table "plannedwork" altered.
2015-06-11 02:40:57 ===== TRACE ===== Table "ticket" altered.
2015-06-11 02:40:57 ===== TRACE ===== Table "activity" altered.
2015-06-11 02:40:57 ===== TRACE ===== Table "milestone" altered.
2015-06-11 02:40:57 ===== TRACE ===== Table "affectation" altered.
2015-06-11 02:40:57 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:57 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:57 ===== TRACE ===== =====================================
2015-06-11 02:40:57 ===== TRACE ===== VERSION V1.8.0
2015-06-11 02:40:57 ===== TRACE ===== Table "indicator" created.
2015-06-11 02:40:57 ===== TRACE ===== 14 lines inserted into table "indicator".
2015-06-11 02:40:57 ===== TRACE ===== Table "indicatorable" created.
2015-06-11 02:40:57 ===== TRACE ===== 8 lines inserted into table "indicatorable".
2015-06-11 02:40:57 ===== TRACE ===== Table "indicatorableindicator" created.
2015-06-11 02:40:57 ===== TRACE ===== Index "indicatorableindicatorIndicatorable" created.
2015-06-11 02:40:57 ===== TRACE ===== Index "indicatorableindicatorIndicator" created.
2015-06-11 02:40:58 ===== TRACE ===== 33 lines inserted into table "indicatorableindicator".
2015-06-11 02:40:58 ===== TRACE ===== Table "indicatordefinition" created.
2015-06-11 02:40:58 ===== TRACE ===== Index "indicatordefinitionIndicatorable" created.
2015-06-11 02:40:58 ===== TRACE ===== Index "indicatordefinitionIndicator" created.
2015-06-11 02:40:58 ===== TRACE ===== Index "indicatordefinitionType" created.
2015-06-11 02:40:58 ===== TRACE ===== Table "indicatorvalue" created.
2015-06-11 02:40:58 ===== TRACE ===== Index "indicatorvalueIndicatordefinition" created.
2015-06-11 02:40:58 ===== TRACE ===== Index "indicatorvalueReference" created.
2015-06-11 02:40:58 ===== TRACE ===== Table "alert" created.
2015-06-11 02:40:58 ===== TRACE ===== 5 lines inserted into table "parameter".
2015-06-11 02:40:58 ===== TRACE ===== Table "delayunit" created.
2015-06-11 02:40:58 ===== TRACE ===== 5 lines inserted into table "delayunit".
2015-06-11 02:40:58 ===== TRACE ===== Table "delay" created.
2015-06-11 02:40:58 ===== TRACE ===== 6 lines inserted into table "delay".
2015-06-11 02:40:58 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:40:58 ===== TRACE ===== 3 lines inserted into table "habilitation".
2015-06-11 02:40:58 ===== TRACE ===== 1 lines updated into table "menu".
2015-06-11 02:40:58 ===== TRACE ===== Table "affectation" altered.
2015-06-11 02:40:58 ===== TRACE ===== 0 lines updated into table "affectation".
2015-06-11 02:40:58 ===== TRACE ===== 1 lines inserted into table "parameter".
2015-06-11 02:40:58 ===== TRACE ===== 7 lines inserted into table "habilitation".
2015-06-11 02:40:58 ===== TRACE ===== 1 lines inserted into table "accessprofile".
2015-06-11 02:40:58 ===== TRACE ===== 7 lines inserted into table "accessright".
2015-06-11 02:40:58 ===== TRACE ===== 2 lines inserted into table "habilitation".
2015-06-11 02:40:58 ===== TRACE ===== 1 lines updated into table "habilitation".
2015-06-11 02:40:58 ===== TRACE ===== Table "project" altered.
2015-06-11 02:40:58 ===== TRACE ===== 0 lines updated into table "project".
2015-06-11 02:40:58 ===== TRACE ===== 1 lines updated into table "type".
2015-06-11 02:40:58 ===== TRACE ===== 2 lines inserted into table "parameter".
2015-06-11 02:40:58 ===== TRACE ===== 6 lines inserted into table "indicatordefinition".
2015-06-11 02:40:58 ===== TRACE ===== Table "work" altered.
2015-06-11 02:40:58 ===== TRACE ===== Table "plannedwork" altered.
2015-06-11 02:40:59 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:40:59 ===== TRACE ===== Table "assignment" altered.
2015-06-11 02:40:59 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:40:59 ===== TRACE ===== 2 lines inserted into table "parameter".
2015-06-11 02:40:59 ===== TRACE ===== 1 lines updated into table "accessright".
2015-06-11 02:40:59 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:40:59 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:40:59 ===== TRACE ===== =====================================
2015-06-11 02:40:59 ===== TRACE ===== VERSION V1.9.0
2015-06-11 02:40:59 ===== TRACE ===== 0 lines deleted from table "parameter".
2015-06-11 02:40:59 ===== TRACE ===== 1 lines inserted into table "parameter".
2015-06-11 02:40:59 ===== TRACE ===== Table "type" altered.
2015-06-11 02:40:59 ===== TRACE ===== 0 lines deleted from table "type".
2015-06-11 02:40:59 ===== TRACE ===== 6 lines inserted into table "type".
2015-06-11 02:40:59 ===== TRACE ===== Table "project" altered.
2015-06-11 02:40:59 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:40:59 ===== TRACE ===== 3 lines inserted into table "habilitation".
2015-06-11 02:40:59 ===== TRACE ===== Table "ticket" altered.
2015-06-11 02:40:59 ===== TRACE ===== Table "activity" altered.
2015-06-11 02:40:59 ===== TRACE ===== Table "milestone" altered.
2015-06-11 02:41:00 ===== TRACE ===== Table "expense" altered.
2015-06-11 02:41:00 ===== TRACE ===== Table "risk" altered.
2015-06-11 02:41:00 ===== TRACE ===== Table "action" altered.
2015-06-11 02:41:00 ===== TRACE ===== Table "issue" altered.
2015-06-11 02:41:00 ===== TRACE ===== Table "meeting" altered.
2015-06-11 02:41:00 ===== TRACE ===== Table "decision" altered.
2015-06-11 02:41:00 ===== TRACE ===== Table "question" altered.
2015-06-11 02:41:00 ===== TRACE ===== 46 lines updated into table "type".
2015-06-11 02:41:00 ===== TRACE ===== 2 lines inserted into table "parameter".
2015-06-11 02:41:00 ===== TRACE ===== Table "version" altered.
2015-06-11 02:41:00 ===== TRACE ===== Table "activity" altered.
2015-06-11 02:41:00 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:41:00 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:41:00 ===== TRACE ===== =====================================
2015-06-11 02:41:00 ===== TRACE ===== VERSION V2.0.0
2015-06-11 02:41:00 ===== TRACE ===== Table "activityprice" created.
2015-06-11 02:41:00 ===== TRACE ===== Index "activitypriceProject" created.
2015-06-11 02:41:00 ===== TRACE ===== Index "activitypriceActivityType" created.
2015-06-11 02:41:00 ===== TRACE ===== Index "activitypriceTeam" created.
2015-06-11 02:41:00 ===== TRACE ===== Table "bill" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billBillType" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billProject" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billClient" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billRecipient" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billStatus" created.
2015-06-11 02:41:01 ===== TRACE ===== Table "client" altered.
2015-06-11 02:41:01 ===== TRACE ===== Table "billline" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billlineReference" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billlineTerm" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billlineResource" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "billlineActivityPrice" created.
2015-06-11 02:41:01 ===== TRACE ===== Table "project" altered.
2015-06-11 02:41:01 ===== TRACE ===== Index "projectRecipient" created.
2015-06-11 02:41:01 ===== TRACE ===== Table "recipient" created.
2015-06-11 02:41:01 ===== TRACE ===== Table "term" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "termProject" created.
2015-06-11 02:41:01 ===== TRACE ===== Index "termBill" created.
2015-06-11 02:41:01 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:41:01 ===== TRACE ===== Index "userRecipient" created.
2015-06-11 02:41:01 ===== TRACE ===== Table "work" altered.
2015-06-11 02:41:01 ===== TRACE ===== Index "workBill" created.
2015-06-11 02:41:02 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:41:02 ===== TRACE ===== Index "planningelementBill" created.
2015-06-11 02:41:02 ===== TRACE ===== Table "assignment" altered.
2015-06-11 02:41:02 ===== TRACE ===== 5 lines inserted into table "menu".
2015-06-11 02:41:02 ===== TRACE ===== 1 lines updated into table "menu".
11 Jun 2015 08:39 #2 by babynus
Replied by babynus on topic install problem~ help me
Your installation seems to start correctly.
Don't care about first errors : they appear because database is empty.
They'll be avaided in V5.0.
Then updates start up to V2.0.0, that does not seem complete : I hope you have more complete log file.
What is important is that each step end with "DATABASE UPDATED WITH NO ERROR".
You should have this up to V4.5.
12 Jun 2015 01:54 #3 by mediassu
Replied by mediassu on topic install problem~ help me
extra log information~
what's problem...... i don't know... T.T
2015-06-11 02:41:10 ===== TRACE ===== VERSION V3.3.0
2015-06-11 02:41:10 ===== TRACE ===== Table "today" created.
2015-06-11 02:41:10 ===== TRACE ===== Index "todayUser" created.
2015-06-11 02:41:10 ===== TRACE ===== Table "todayparameter" created.
2015-06-11 02:41:11 ===== TRACE ===== Index "todayParameterUser" created.
2015-06-11 02:41:11 ===== TRACE ===== Index "todayParameterReport" created.
2015-06-11 02:41:11 ===== TRACE ===== Index "todayParameterToiday" created.
2015-06-11 02:41:11 ===== TRACE ===== 2 lines inserted into table "today".
2015-06-11 02:41:11 ===== TRACE ===== Table "" altered.
2015-06-11 02:41:11 ===== TRACE ===== 2 lines inserted into table "parameter".
2015-06-11 02:41:11 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:41:11 ===== TRACE ===== 7 lines inserted into table "habilitation".
2015-06-11 02:41:11 ===== TRACE ===== 1 lines inserted into table "report".
2015-06-11 02:41:11 ===== TRACE ===== 5 lines inserted into table "reportparameter".
2015-06-11 02:41:11 ===== TRACE ===== 3 lines inserted into table "habilitationreport".
2015-06-11 02:41:11 ===== TRACE ===== Table "statusmail" altered.
2015-06-11 02:41:11 ===== TRACE ===== Table "event" altered.
2015-06-11 02:41:11 ===== TRACE ===== 1 lines updated into table "event".
2015-06-11 02:41:11 ===== TRACE ===== 6 lines inserted into table "event".
2015-06-11 02:41:11 ===== TRACE ===== 6 lines inserted into table "parameter".
2015-06-11 02:41:11 ===== TRACE ===== Table "project" altered.
2015-06-11 02:41:11 ===== TRACE ===== Table "document" altered.
2015-06-11 02:41:11 ===== TRACE ===== 6 lines inserted into table "planningmode".
2015-06-11 02:41:11 ===== TRACE ===== 1 lines inserted into table "planningmode".
2015-06-11 02:41:11 ===== TRACE ===== 8 lines inserted into table "mailable".
2015-06-11 02:41:11 ===== TRACE ===== Table "testsession" altered.
2015-06-11 02:41:11 ===== TRACE ===== Table "meeting" altered.
2015-06-11 02:41:11 ===== TRACE ===== 1 lines inserted into table "indicatorable".
2015-06-11 02:41:11 ===== TRACE ===== 11 lines inserted into table "indicatorableindicator".
2015-06-11 02:41:11 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:41:11 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:41:11 ===== TRACE ===== =====================================
2015-06-11 02:41:11 ===== TRACE ===== VERSION V3.3.1
2015-06-11 02:41:11 ===== TRACE ===== 1 lines inserted into table "dependable".
2015-06-11 02:41:11 ===== TRACE ===== VERSION V3.4.0
2015-06-11 02:41:11 ===== TRACE ===== 1 lines inserted into table "parameter".
2015-06-11 02:41:11 ===== TRACE ===== Table "type" altered.
2015-06-11 02:41:12 ===== TRACE ===== Table "expensedetailtype" altered.
2015-06-11 02:41:12 ===== TRACE ===== Table "contexttype" altered.
2015-06-11 02:41:12 ===== TRACE ===== Table "mail" altered.
2015-06-11 02:41:12 ===== TRACE ===== Table "note" altered.
2015-06-11 02:41:12 ===== TRACE ===== Table "meeting" altered.
2015-06-11 02:41:12 ===== TRACE ===== Index "meetingPeriodicMeeting" created.
2015-06-11 02:41:12 ===== TRACE ===== Table "periodicmeeting" created.
2015-06-11 02:41:12 ===== TRACE ===== Index "periodicmeetingProject" created.
2015-06-11 02:41:12 ===== TRACE ===== Index "periodicmeetingType" created.
2015-06-11 02:41:12 ===== TRACE ===== Index "periodicmeetingUser" created.
2015-06-11 02:41:12 ===== TRACE ===== Index "periodicmeetingResource" created.
2015-06-11 02:41:12 ===== TRACE ===== 1 lines inserted into table "parameter".
2015-06-11 02:41:12 ===== TRACE ===== Table "indicatordefinition" altered.
2015-06-11 02:41:12 ===== TRACE ===== 1 lines inserted into table "linkable".
2015-06-11 02:41:12 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:41:12 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:41:12 ===== TRACE ===== 7 lines inserted into table "habilitation".
2015-06-11 02:41:12 ===== TRACE ===== 7 lines inserted into table "accessright".
2015-06-11 02:41:12 ===== TRACE ===== Table "periodicity" created.
2015-06-11 02:41:12 ===== TRACE ===== 5 lines inserted into table "periodicity".
2015-06-11 02:41:12 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:41:12 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:41:12 ===== TRACE ===== =====================================
2015-06-11 02:41:12 ===== TRACE ===== VERSION V3.4.1
2015-06-11 02:41:12 ===== TRACE ===== 0 lines updated into table "assignment".
2015-06-11 02:41:12 ===== TRACE ===== 0 lines updated into table "work".
2015-06-11 02:41:12 ===== TRACE ===== VERSION V4.0.0
2015-06-11 02:41:12 ===== TRACE ===== Table "command" created.
2015-06-11 02:41:12 ===== TRACE ===== Index "commandProject" created.
2015-06-11 02:41:12 ===== TRACE ===== Index "commandUser" created.
2015-06-11 02:41:12 ===== TRACE ===== Index "commandResource" created.
2015-06-11 02:41:13 ===== TRACE ===== Index "commandStatus" created.
2015-06-11 02:41:13 ===== TRACE ===== Index "commandType" created.
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "type".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:41:13 ===== TRACE ===== 7 lines inserted into table "habilitation".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "accessright".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "originable".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "mailable".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "linkable".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "referencable".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "indicatorable".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "importable".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "copyable".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "indicatorableindicator".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "report".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "reportparameter".
2015-06-11 02:41:13 ===== TRACE ===== 3 lines inserted into table "habilitationreport".
2015-06-11 02:41:13 ===== TRACE ===== 1 lines inserted into table "planningmode".
2015-06-11 02:41:13 ===== TRACE ===== Table "project" altered.
2015-06-11 02:41:13 ===== TRACE ===== Table "document" altered.
2015-06-11 02:41:13 ===== TRACE ===== Table "statusmail" altered.
2015-06-11 02:41:13 ===== TRACE ===== Table "overallprogress" created.
2015-06-11 02:41:13 ===== TRACE ===== 7 lines inserted into table "overallprogress".
2015-06-11 02:41:13 ===== TRACE ===== 0 lines updated into table "planningelement".
2015-06-11 02:41:13 ===== TRACE ===== 0 lines updated into table "document".
2015-06-11 02:41:13 ===== TRACE ===== Table "columnselector" created.
2015-06-11 02:41:13 ===== TRACE ===== Index "scopeColumnSelector" created.
2015-06-11 02:41:13 ===== TRACE ===== Table "audit" altered.
2015-06-11 02:41:13 ===== TRACE ===== 2 lines updated into table "parameter".
2015-06-11 02:41:13 ===== TRACE ===== 0 lines updated into table "parameter".
2015-06-11 02:41:13 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:41:13 ===== TRACE ===== 0 lines updated into table "resource".
2015-06-11 02:41:13 ===== TRACE ===== Table "status" altered.
2015-06-11 02:41:13 ===== TRACE ===== 1 lines updated into table "status".
2015-06-11 02:41:13 ===== TRACE ===== Table "type" altered.
2015-06-11 02:41:13 ===== TRACE ===== 53 lines updated into table "type".
2015-06-11 02:41:14 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:41:14 ===== TRACE ===== Table "project" altered.
2015-06-11 02:41:14 ===== TRACE ===== 0 lines updated into table "project".
2015-06-11 02:41:14 ===== TRACE ===== 0 lines updated into table "planningelement".
2015-06-11 02:41:14 ===== TRACE ===== Table "ticket" altered.
2015-06-11 02:41:14 ===== TRACE ===== 0 lines updated into table "ticket".
2015-06-11 02:41:14 ===== TRACE ===== Table "activity" altered.
2015-06-11 02:41:14 ===== TRACE ===== 0 lines updated into table "activity".
2015-06-11 02:41:14 ===== TRACE ===== Table "milestone" altered.
2015-06-11 02:41:14 ===== TRACE ===== 0 lines updated into table "milestone".
2015-06-11 02:41:14 ===== TRACE ===== Table "action" altered.
2015-06-11 02:41:14 ===== TRACE ===== Table "risk" altered.
2015-06-11 02:41:14 ===== TRACE ===== 0 lines updated into table "risk".
2015-06-11 02:41:14 ===== TRACE ===== Table "opportunity" altered.
2015-06-11 02:41:14 ===== TRACE ===== 0 lines updated into table "opportunity".
2015-06-11 02:41:14 ===== TRACE ===== Table "document" altered.
2015-06-11 02:41:14 ===== TRACE ===== 0 lines updated into table "document".
2015-06-11 02:41:15 ===== TRACE ===== Table "issue" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "issue".
2015-06-11 02:41:15 ===== TRACE ===== Table "requirement" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "requirement".
2015-06-11 02:41:15 ===== TRACE ===== Table "testcase" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "testcase".
2015-06-11 02:41:15 ===== TRACE ===== Table "question" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "question".
2015-06-11 02:41:15 ===== TRACE ===== Table "decision" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "decision".
2015-06-11 02:41:15 ===== TRACE ===== Table "expense" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "expense".
2015-06-11 02:41:15 ===== TRACE ===== Table "bill" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "bill".
2015-06-11 02:41:15 ===== TRACE ===== Table "testsession" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "testsession".
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "planningelement".
2015-06-11 02:41:15 ===== TRACE ===== Table "meeting" altered.
2015-06-11 02:41:15 ===== TRACE ===== 0 lines updated into table "meeting".
2015-06-11 02:41:15 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:41:15 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:41:15 ===== TRACE ===== =====================================
2015-06-11 02:41:15 ===== TRACE ===== VERSION V4.0.1
2015-06-11 02:41:16 ===== TRACE ===== Table "command" altered.
2015-06-11 02:41:16 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:41:16 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:41:16 ===== TRACE ===== =====================================
2015-06-11 02:41:16 ===== TRACE ===== VERSION V4.1.-
2015-06-11 02:41:16 ===== TRACE ===== 0 lines deleted from table "columnselector".
2015-06-11 02:41:16 ===== TRACE ===== 0 lines updated into table "columnselector".
2015-06-11 02:41:16 ===== TRACE ===== 0 lines deleted from table "workelement".
2015-06-11 02:41:16 ===== TRACE ===== Table "quality" created.
2015-06-11 02:41:16 ===== TRACE ===== 3 lines inserted into table "quality".
2015-06-11 02:41:16 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:41:16 ===== TRACE ===== 7 lines inserted into table "habilitation".
2015-06-11 02:41:16 ===== TRACE ===== Table "trend" created.
2015-06-11 02:41:16 ===== TRACE ===== 3 lines inserted into table "trend".
2015-06-11 02:41:16 ===== TRACE ===== Table "project" altered.
2015-06-11 02:41:16 ===== TRACE ===== Table "health" altered.
2015-06-11 02:41:16 ===== TRACE ===== Table "type" altered.
2015-06-11 02:41:16 ===== TRACE ===== VERSION V4.1.0
2015-06-11 02:41:16 ===== TRACE ===== Table "calendardefinition" created.
2015-06-11 02:41:16 ===== TRACE ===== 1 lines inserted into table "calendardefinition".
2015-06-11 02:41:16 ===== TRACE ===== Table "calendar" altered.
2015-06-11 02:41:16 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:41:16 ===== TRACE ===== Table "client" altered.
2015-06-11 02:41:16 ===== TRACE ===== VERSION V4.2.0
2015-06-11 02:41:16 ===== TRACE ===== Table "checklistdefinition" created.
2015-06-11 02:41:16 ===== TRACE ===== Index "checklistdefinitionChecklistable" created.
2015-06-11 02:41:16 ===== TRACE ===== Index "checklistdefinitionNameChecklistable" created.
2015-06-11 02:41:16 ===== TRACE ===== Index "checklistdefinitionType" created.
2015-06-11 02:41:16 ===== TRACE ===== Table "checklistdefinitionline" created.
2015-06-11 02:41:16 ===== TRACE ===== Index "checklistdefinitionlineChecklistDefinition" created.
2015-06-11 02:41:17 ===== TRACE ===== Table "checklist" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "checklistReference" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "checklistChecklistDefinition" created.
2015-06-11 02:41:17 ===== TRACE ===== Table "checklistline" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "checklistlineChecklist" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "checklistlineChecklistDefinitionLine" created.
2015-06-11 02:41:17 ===== TRACE ===== 1 lines updated into table "menu".
2015-06-11 02:41:17 ===== TRACE ===== 0 lines updated into table "menu".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:41:17 ===== TRACE ===== 7 lines inserted into table "habilitation".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "referencable".
2015-06-11 02:41:17 ===== TRACE ===== Table "checklistable" created.
2015-06-11 02:41:17 ===== TRACE ===== 16 lines inserted into table "checklistable".
2015-06-11 02:41:17 ===== TRACE ===== 7 lines inserted into table "habilitationother".
2015-06-11 02:41:17 ===== TRACE ===== Table "quotation" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "quotationProject" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "quotationUser" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "quotationResource" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "quotationStatus" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "quotationType" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "quotationClient" created.
2015-06-11 02:41:17 ===== TRACE ===== Index "quotationContact" created.
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "type".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "accessright".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "originable".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "mailable".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "linkable".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "indicatorable".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "importable".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "copyable".
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "indicatorableindicator".
2015-06-11 02:41:17 ===== TRACE ===== Table "product" altered.
2015-06-11 02:41:17 ===== TRACE ===== 1 lines inserted into table "parameter".
2015-06-11 02:41:17 ===== TRACE ===== Table "filtercriteria" altered.
2015-06-11 02:41:17 ===== TRACE ===== Table "command" altered.
2015-06-11 02:41:18 ===== TRACE ===== Table "bill" altered.
2015-06-11 02:41:18 ===== TRACE ===== 1 lines inserted into table "copyable".
2015-06-11 02:41:18 ===== TRACE ===== 1 lines deleted from table "menu".
2015-06-11 02:41:18 ===== TRACE ===== Table "report" altered.
2015-06-11 02:41:18 ===== TRACE ===== 7 lines inserted into table "habilitationother".
2015-06-11 02:41:18 ===== TRACE ===== Table "requirement" altered.
2015-06-11 02:41:18 ===== TRACE ===== 1 lines inserted into table "indicatorable".
2015-06-11 02:41:18 ===== TRACE ===== 1 lines inserted into table "indicatorableindicator".
2015-06-11 02:41:18 ===== TRACE ===== 2 lines inserted into table "parameter".
2015-06-11 02:41:18 ===== TRACE ===== 2 lines updated into table "menu".
2015-06-11 02:41:18 ===== TRACE ===== 0 lines updated into table "menu".
2015-06-11 02:41:18 ===== TRACE ===== 1 lines updated into table "menu".
2015-06-11 02:41:18 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:41:18 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:41:18 ===== TRACE ===== =====================================
2015-06-11 02:41:18 ===== TRACE ===== VERSION V4.2.1
2015-06-11 02:41:18 ===== TRACE ===== Table "quotation" altered.
2015-06-11 02:41:19 ===== TRACE ===== Table "command" altered.
2015-06-11 02:41:19 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:41:19 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:41:19 ===== TRACE ===== =====================================
2015-06-11 02:41:19 ===== TRACE ===== VERSION V4.3.0.a
2015-06-11 02:41:19 ===== TRACE ===== 1 lines inserted into table "menu".
2015-06-11 02:41:19 ===== TRACE ===== 7 lines inserted into table "habilitation".
2015-06-11 02:41:19 ===== TRACE ===== 7 lines inserted into table "habilitationother".
2015-06-11 02:41:19 ===== TRACE ===== 0 lines updated into table "project".
2015-06-11 02:41:19 ===== TRACE ===== 2 lines inserted into table "type".
2015-06-11 02:41:19 ===== TRACE ===== Table "client" altered.
2015-06-11 02:41:19 ===== TRACE ===== Index "clientClientType" created.
2015-06-11 02:41:19 ===== TRACE ===== 1 lines inserted into table "report".
2015-06-11 02:41:19 ===== TRACE ===== 2 lines inserted into table "reportparameter".
2015-06-11 02:41:19 ===== TRACE ===== 3 lines inserted into table "habilitationreport".
2015-06-11 02:41:19 ===== TRACE ===== VERSION V4.3.2
2015-06-11 02:41:19 ===== TRACE ===== 0 lines deleted from table "planningelement".
2015-06-11 02:41:19 ===== TRACE ===== 1 lines updated into table "report".
2015-06-11 02:41:19 ===== TRACE ===== VERSION V4.4.0
2015-06-11 02:41:19 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:41:19 ===== TRACE ===== 3 lines inserted into table "reportparameter".
2015-06-11 02:41:19 ===== TRACE ===== 7 lines inserted into table "habilitationreport".
2015-06-11 02:41:19 ===== TRACE ===== 2 lines inserted into table "mailable".
2015-06-11 02:41:19 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:41:19 ===== TRACE ===== 0 lines updated into table "planningelement".
2015-06-11 02:41:20 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:41:20 ===== TRACE ===== 0 lines updated into table "planningelement".
2015-06-11 02:41:21 ===== TRACE ===== Table "resource" altered.
2015-06-11 02:41:21 ===== TRACE ===== Parameter $enforceUTF8 added
2015-06-11 02:41:21 ===== TRACE ===== DATABASE UPDATED
2015-06-11 02:41:21 ===== TRACE ===== WITH NO ERROR
2015-06-11 02:41:21 ===== TRACE ===== =====================================
2015-06-11 02:41:21 ===== TRACE ===== VERSION V4.5.0
2015-06-11 02:41:21 ===== TRACE ===== 1 lines updated into table "accessprofile".
2015-06-11 02:41:21 ===== TRACE ===== 1 lines inserted into table "dependable".
2015-06-11 02:41:21 ===== TRACE ===== 2 lines updated into table "planningmode".
2015-06-11 02:41:21 ===== TRACE ===== 1 lines inserted into table "accessscope".
2015-06-11 02:41:21 ===== TRACE ===== Table "audit" altered.
2015-06-11 02:41:21 ===== TRACE ===== 0 lines deleted from table "columnselector".
2015-06-11 02:41:21 ===== TRACE ===== 0 lines updated into table "assignment".
2015-06-11 02:41:21 ===== TRACE ===== Table "assignment" altered.
2015-06-11 02:41:21 ===== TRACE ===== Table "planningelement" altered.
2015-06-11 02:41:21 ===== TRACE ===== VERSION V4.5.3
2015-06-11 02:41:21 ===== TRACE ===== Table "tempupdate" created.
2015-06-11 02:41:21 ===== TRACE ===== 0 lines deleted from table "tempupdate".
2015-06-11 02:41:21 ===== TRACE ===== 0 lines inserted into table "tempupdate".
2015-06-11 02:41:21 ===== TRACE ===== 0 lines deleted from table "workelement".
2015-06-11 02:41:21 ===== TRACE ===== VERSION V4.5.6
2015-06-11 02:41:21 ===== TRACE ===== 0 lines updated into table "planningelement".
2015-06-11 02:41:21 ===== TRACE ===== 1 lines inserted into table "planningmode".
2015-06-11 02:41:21 ===== TRACE ===== 3 lines inserted into table "report".
2015-06-11 02:41:21 ===== TRACE ===== 9 lines inserted into table "reportparameter".
2015-06-11 02:41:21 ===== TRACE ===== 21 lines inserted into table "habilitationreport".
2015-06-11 02:41:21 ===== TRACE ===== 7 lines inserted into table "habilitationother".
2015-06-11 02:41:21 ===== TRACE ===== create default project
2015-06-11 02:41:21 ===== TRACE ===== === REWRITE PARAMTERS.PHP FILE = START ====================
2015-06-11 02:41:21 ===== TRACE ===== $paramDbType kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramDbHost kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramDbPort kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramDbUser kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramDbPassword kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramDbName kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramDbDisplayName moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramDbPrefix kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_allow_login kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_base_dn kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_host kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_port kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_version kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_search_user kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_search_pass kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_user_filter kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramMailSender moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramMailReplyTo moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramAdminMail moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramMailSmtpServer moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramMailSmtpPort moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramMailSendmailPath moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramDefaultPassword kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramPasswordMinLength kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramDefaultLocale kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramDefaultTimezone kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $currency kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $currencyPosition kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramFadeLoadingMode kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramIconSize kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $defaultTheme kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramAttachementDirectory kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramAttachementMaxSize kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramReportTempDirectory kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $paramMemoryLimitForPDF kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $logFile kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $logLevel kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== $enforceUTF8 kept in parameter file
2015-06-11 02:41:21 ===== TRACE ===== ---> lines read from file = 44
2015-06-11 02:41:21 ===== TRACE ===== ---> parameters found = 38
2015-06-11 02:41:21 ===== TRACE ===== ---> parameters moved to database = 7
2015-06-11 02:41:21 ===== TRACE ===== ---> parameters kept in parameter file = 31
2015-06-11 02:41:21 ===== TRACE ===== REWRITE PARAMTERS.PHP FILE = END ======================
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_allow_login moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_base_dn moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_host moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_port moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_version moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_search_user moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_search_pass moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramLdap_user_filter moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramDefaultPassword moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramPasswordMinLength moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramDefaultLocale moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramDefaultTimezone moved to database
2015-06-11 02:41:21 ===== TRACE ===== $currency moved to database
2015-06-11 02:41:21 ===== TRACE ===== $currencyPosition moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramFadeLoadingMode moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramIconSize moved to database
2015-06-11 02:41:21 ===== TRACE ===== $defaultTheme moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramAttachementDirectory moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramAttachementMaxSize moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramReportTempDirectory moved to database
2015-06-11 02:41:21 ===== TRACE ===== $paramMemoryLimitForPDF moved to database
2015-06-11 02:41:21 ===== TRACE ===== ---> lines read from file = 37
2015-06-11 02:41:21 ===== TRACE ===== ---> parameters found = 31
2015-06-11 02:41:21 ===== TRACE ===== ---> parameters moved to database = 21
2015-06-11 02:41:21 ===== TRACE ===== ---> parameters kept in parameter file = 10
2015-06-11 02:41:21 ***** ERROR ***** ERROR *****
2015-06-11 02:41:21 ***** ERROR ***** on file 'C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php' at line (2768)
2015-06-11 02:41:21 ***** ERROR ***** cause = Undefined index: user
2015-06-11 03:00:40 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.user' doesn't exist
2015-06-11 03:00:40 ***** ERROR ***** For query : desc user
2015-06-11 03:00:40 ***** ERROR ***** Strack trace :
2015-06-11 03:00:40 ***** ERROR ***** #0 Sql->query called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:2195]
2015-06-11 03:00:40 ***** ERROR ***** #1 SqlElement->getFormatList called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1952]
2015-06-11 03:00:40 ***** ERROR ***** #2 SqlElement->getDataType called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1484]
2015-06-11 03:00:40 ***** ERROR ***** #3 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\projeqtor\tool\loginCheck.php:61]
2015-06-11 03:00:40 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2015-06-11 03:00:40 ***** ERROR ***** #0 Sql->query called at [C:\inetpub\wwwroot\projeqtor\model\persistence\SqlElement.php:1517]
2015-06-11 03:00:40 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\projeqtor\tool\loginCheck.php:61]
2015-06-11 03:00:40 ===== TRACE ===== Login error for user 'admin'
12 Jun 2015 10:55 - 12 Jun 2015 10:56 #4 by babynus
Try and clean browser cache and try again.
Last edit: 12 Jun 2015 10:56 by babynus.
