ProjeQtOr free project management software - [SOLVED] Major problem 5.3.1 : Mutex problem (creating activity problem) - ProjeQtOr
30 Mar 2016 09:40 #1 by loich974
Hi everybody,
I recently installed Projeqtor 5.3.0 and I upgraded this to 5.31 few minutes ago.
I had a problem with the 5.3.0 version and it continues with the version 5.3.1.
I can not add Activity to my project, if I try, I have an error message saying "please contact an administrator". I checked log file and I see these lines :
"2016-03-30 08:21:49.845 ***** ERROR ***** ERROR *****
2016-03-30 08:21:49.845 ***** ERROR ***** on file 'C:\xampp\htdocs\projeqtor\model\Mutex.php' at line (29)
2016-03-30 08:21:49.845 ***** ERROR ***** cause = Methods with the same name as their class will not be constructors in a future version of PHP; Mutex has a deprecated constructor"
May you help us please.
It's a critical problem for us. We use the platform to manage project and the application is not available and not usable because we can't create activities and it's the same problem with tickets and others functionnalities.
Thanks for your time.
I hope this will be fixed a.s.a.p
Loïc
30 Mar 2016 10:04 #2 by babynus
which version of php do you use ?
nb : Projeqtor has not yet been validated for php 7
as you issue is a warning only, you can have a workaround settion log level to error in php.ini
30 Mar 2016 10:32 #3 by loich974
Thanks for you quick reply.
I use php 7, maybe this is the problem.
Modify log level doesn't solve my problem, I still have the error message when I try to create an activity (have a look to my screenshot)
Does Projeqtor v5.3.1 work with php 5.6 ?
31 Mar 2016 02:39 #4 by babynus
papjul proposed a fix.
It will be included in next patch.
31 Mar 2016 07:32 #5 by loich974
As you said my problem is about my php version, I created an export of my database and I downgraded my php version to the 5.6 (changing xampp version) and I reinstalled projeqtor in a new directory. I always can't create an activity but the message is different and worst I think. Have a look
31 Mar 2016 10:42 #6 by loich974
I solved my problem.
It was my export file, it was corrupted. I had another export file a little bit older than the current I used. So I reinstalled and configured my Xampp (with php7) and used the correct export file, then I applied the papjul fix and it worked.
Thanks a lot babynus and papjul. It works properly and with php7 it's faster.
