ProjeQtOr free project management software - [SOLVED] Error trying to add a Project - ProjeQtOr
13 May 2019 11:53 #1 by pakkes
I've installed Projeqtor 8.0.2 on a Apache 2.4 + Php 7.1.10 environment, on Windows 7 64bit. All ran as expected during installation and first setup.
However, I get an error while adding a new Project. The log tells that ...
2019-05-13 00:39:11.747 ***** ERROR ***** [V8.0.2] ERROR *****
2019-05-13 00:39:11.749 ***** ERROR ***** [V8.0.2] on file 'C:\Apache-2.4\htdocs\projeqtor\model\persistence\SqlElement.php' at line (2732)
2019-05-13 00:39:11.750 ***** ERROR ***** [V8.0.2] cause = Event::__construct() expects at least 4 parameters, 0 given
Any suggestion on how to avoid this error?
I first tried to use the 7.4.4 version of Projeqtor and getting the same exact error, so I moved to 8.0.2 ... same result.
Many thanks in advance for your help.
13 May 2019 19:09 #2 by babynus
Very stange, you get an error on some line that is called 1000 ties a day on active instance.
Possibly there is soething weird on your PHP Configuration, but I cannot guess what.
Try and remove E_STRICT mode on php.ini
error_reporting = E_ALL
13 May 2019 19:42 #3 by pakkes
Hi.
Many thanks for the immediate reply!!!
I tried your suggestion .... I get same result.
Is there something I can do in order to give you more info about this?
14 May 2019 09:55 #4 by babynus
Did you restart PHP after change in php.ini ?
14 May 2019 10:00 #5 by pakkes
yes, it shows 32767 with phpinfo(), it should be equal to E_ALL
14 May 2019 10:19 #6 by babynus
So we'll have to run some debug.
Can you pkease add 1 line in model/persistence/SqlElement before line 2732, this way :
  public static function getSingleSqlElementFromCriteria($class, $critArray, $withoutDepedentElements=false) {
    debugLog("getSingleSqlElementFromCriteria('$class')");
    $obj = new $class();
Then change logLevel to '3' in parameters.php.
Run projeqtor.
Post here trace found in log file.
