ProjeQtOr free project management software - Mismatch between Manual and GUI - ProjeQtOr
21 May 2019 23:57 #1 by gohrner
I found a mismatch between the mail receivers description in the manual and how it's actually called in the GUI (English language settings).
The following types of receivers are documented in the manual:
(ControlAutomation.html#receivers-list)
  • Requestor
  • Issuer
  • Responsible
  • Project team
  • Project leader
  • Project manager
  • Assigned resource
  • Other
However, the actually displayed options in the GUI are:
(list copied from Controls & Automation => Mails on events)
  • requestor
  • issuer
  • responsible
  • project team
  • global project team
  • project leader
  • project manager
  • followers
  • other
So "global project team" and "followers" are not explained in the manual while "Assigned resource" is explained in the manual, but does not appear in the GUI.
Is "Assigned resource" the same as "followers"?
Or are follower the Item's subscribers?
22 May 2019 22:01 #2 by babynus
User guide is not up to date.
We are working on this part, hope we'll include more accurate version on V8.1
