ProjeQtOr free project management software - History of modifications : Displaying issue - ProjeQtOr
05 Sep 2019 09:13 #1 by fmartin
Hi, I noticed that there is displaying issue in the section of "History of Modifications" in the ticket view.
When the creator of the ticket copy/paste an image, or a long string in the description box, the history of modifications display is impacted and truncate the information.
Whatever the browser used, we cannot see anymore the username/timestamp of the lines for each modification.
See attachment for better understanding of the issue.
05 Sep 2019 10:52 #2 by babynus
I cannot reproduce.
I have test case on Demo (demo.projeqtor.org), on Ticket #82, you can have a look connecting with user manager
1) which version of projeqtor are you using ?
2) Can you try and reproduce on Demo ? (possibly issue comes from text copied)
05 Sep 2019 14:30 #3 by fmartin
I connected on the demo platform. I added a screenshot in the description text box, and I screwed the display. Please have a look ;).
I'm using 8.0.6 version
05 Sep 2019 15:04 #4 by babynus
OK, I understand now.
The image is very large and so right part of the table is hidden.
Scrollbars are missing :(
Ticket #4091 recorded
NB : as a work around, you can change display of history parameter (in user parameter screen) from "YES" to "On Request".
Then history is displayed on request (click on hourglass button) in a pop-up, and there you get scroll bars ;)
Thanks for reporting the issue and the use case.
The following user(s) said Thank You: fmartin
