ProjeQtOr free project management software - Error in "Portefeuil de projet" view - ProjeQtOr
20 Jan 2020 16:50 #1 by Bena
When I clic on the "Portefeuil de projet" tab, nothing appear.
And I have the follonwing error in the log file :
2020-01-20 16:21:39.841 ***** ERROR ***** [V8.3.1] ERROR *****
2020-01-20 16:21:39.841 ***** ERROR ***** [V8.3.1] on file '/projeqtor/projeqtor/tool/jsonPlanning.php' at line (471)
2020-01-20 16:21:39.841 ***** ERROR ***** [V8.3.1] cause = Undefined offset: 82
Regards.
PS : Happy new year :)
Bena
21 Jan 2020 12:24 #2 by Flou
You have an inconsistency with your project, that's why you got an error.
You have an open milestone on a closed project, you you must close the milestone or reopened the project.
PS: thank's and happy new year too .
21 Jan 2020 13:36 #3 by Bena
Is there a way to find the project or the milestone name or ID ?
Bena
21 Jan 2020 15:16 #4 by Flou
You can find the milestone by displaying the closed items.
You should find the milestone that is related to your closed project.
22 Jan 2020 21:27 #5 by Bena
ok but it will take some times ... I have a lot of closed projects -_-
Bena
23 Jan 2020 08:53 #6 by 4ce
maybe making a csv-export could help. you can use the excel filtering options, which could be a good help to identify milestones related to some projects?
good luck
The following user(s) said Thank You: Bena
