ProjeQtOr free project management software - Periodic meeting - Page 4 - ProjeQtOr
Periodic meeting
26 Mar 2020 20:35 #19 by babynus
Replied by babynus on topic Periodic meeting
To help us understand what happens, please get attached patch.
Install it (file PeriodicMeetingMain.php must replacer existing one in directory "model")
Be sure that logLevel=2 ou 3 in parameters.php.
Execute test case.
Post here log file.
02 Apr 2020 16:15 #20 by mcambron@videotron.ca
Bonjour Équipe ProjeQtOr ,
Please find the log file following the installation of your patch. I tried to program a periodic meeting and this was done before the creation of the the log file.
Michel
05 Apr 2020 13:51 #21 by babynus
Have asimple look at the log file :
2020-04-02 09:01:57.006 ===== TRACE ===== result of save() = <b>Contrôles invalides.</b><br/><br/>Le champ 'ordre du jour' est obligatoire<input type="hidden" id="lastOperationStatus" value="INVALID" /><input type="hidden" id="lastSaveId" value="" /><input type="hidden" id="lastOperation" value="control" />
You set "ordre du jour" (field description) as required on meetings, but did not define it on your periodic meeting.
So insertion fails.
Just remove the control (on type of meeting) or add description on your periodic meeting to allow creation of meetings.
06 Apr 2020 14:38 #22 by mcambron@videotron.ca
Bonjour ProjeQtOr team,
Yes, it now works. Usually,ProjeQtOr does not allow you to crate an element if a mandatory field is left empty.
As a suggestion, can the periodic meeting have the same rule as the other elements (meeting, activities…) with respect to the entry of mandatory information in order to be created?
Thank you for your help and patience!
Michel
