ProjeQtOr free project management software - [SOLVED] Mailing configuration not saved - ProjeQtOr
21 Apr 2020 11:04 #1 by fmt
When configuring mailing parameters, sending test mail returns a PHPMail error. Checking error log does not reflect actual configuration I set up in Mailing parameters, but default parameters instead (e.g. smtp server is 'localhost', port is '25').
Someting I missed somewhere ?
21 Apr 2020 16:19 #2 by babynus
It may happen that some parameters "remained" in the parameters.php file
Locate this file and check that no mailing parameter is still there.
Only parameters for db access and logging should remain here.
The following user(s) said Thank You: fmt
21 Apr 2020 18:08 #3 by fmt
Replied by fmt on topic Mailing configuration not saved
Configuration is now empty of default parameters. thanks.
I now have to find a correct configuration :)
Thanks,
