ProjeQtOr free project management software - [SOLVED] Unable to create new project, activity, milestone - ProjeQtOr
18 Aug 2020 09:41 - 18 Aug 2020 09:41 #1 by timshel
It's impossible to create a new activity, project or milestone with the button "create a new item" (see attached file).
I try this in Firefox and Microsoft Edge.
Best regards
Timshel
Last edit: 18 Aug 2020 09:41 by timshel.
18 Aug 2020 10:27 #2 by Flou
Have you the right access for "create a new item" ?
if you have right access, have you an issue in files log ?
18 Aug 2020 10:41 #3 by timshel
I've an administrator profile.
No issue in the log file, just the connection trace.
No actin when I click on the button (no menu like "create new project"...).
Issue since upgrade from v8.5.3 to v8.5.4.
I try to reinstall (overwrite) v8.5.4, same problem on both browser.
OS = Ubuntu 18.04
18 Aug 2020 10:56 #4 by babynus
I cannot reproduce on V8.5.4.
Try and clean browser cache.
If issue pesists, look for error in browser console and post errors here.
18 Aug 2020 11:41 #5 by timshel
I've clear the browser cache. Same problem.
Find in attached file the browser console error message.
18 Aug 2020 11:58 #6 by babynus
Issue confirmed.
It occurs only on specific use case : when you select "planning" as first screen and directly add item without any navigation.
Try and change screen and then try again : all will work fine.
Issue recorded as ticket #4843
