ProjeQtOr free project management software - Difficulty to import project update - Page 2 - ProjeQtOr
05 Sep 2020 11:16 #7 by babynus
This is effectively an error in external library XLSXReader.
The fix you propose seem correct, we'll inculde it in V8.5.5.
We'll try and upgrade this external library on V8.6.0 to check if XLSReader team already fixed the issue.
You possibly don't have issue on your VM if:
- you PHP version is lower than 7.4
- log level in your php.ini does not trace deprecation
