ProjeQtOr free project management software - [SOLVED] Updating V8.3.4 to V8.5.4 - ProjeQtOr
03 Sep 2020 02:27 #1 by Cjaxen
I copied over all the V8.5.4 files by ftp, but logging in... still shows V8.3.4.
Not sure what I am doing wrong. I copy them over from new download, and can log in.
03 Sep 2020 07:50 #2 by ashofphoenix
did you log in using admin right to start the real update ? Usually you have a reminder that only admin could log to make update
03 Sep 2020 09:41 #3 by Cjaxen
Replied by Cjaxen on topic Updating V8.3.4 to V8.5.4
Sorry, now I feel really stupid. It's been awhile (V8.3.4) and I don't remember updating from admin (which I am logged in with admin rights).
Where in the admin area can I do this?
03 Sep 2020 10:28 - 03 Sep 2020 10:29 #4 by ashofphoenix
Usually, you just have to log in with admin right and it starts the upgrade. When it's finished you should have a quick resume popup and then all should be fine
I keep the original admin account with a specific password and remove admin right from my own account. A choice to be sure to do that properly
Last edit: 03 Sep 2020 10:29 by ashofphoenix.
03 Sep 2020 21:37 #5 by Cjaxen
I have 2 admin accounts, and barely use them. I logged into both and I get the V8.3.5 popup update but no notice of any updates. Still at V8.3.4
Any way to force it?
04 Sep 2020 07:29 #6 by ashofphoenix
Don't have that kind of problem. At least, did you have the notification of update on the log-in script telling "only admin can log"...
Stupid question but are you sure to have correctly overridden the previous installation on the same path on your server ? (it happened to be once, that's why I ask... Otherwise, you will have to ask for a ProjeQtor Team answer :pinch:
