ProjeQtOr free project management software - new project impossible - ProjeQtOr
18 Jan 2021 15:27 #1 by conan
new project impossible was created by conan
Since the new upgrade of Projeqtor (V8.5.4), we have big problem off slowness : 15 seconds to register imputation, creating new Projeqt is imposible now...
Here some php log :
[18-Jan-2021 14:41:40 Europe/Paris] PHP Fatal error:  Maximum execution time of 30 seconds exceeded in C:\Outils\www\projeqtor\model\Module.php on line 108
[18-Jan-2021 14:41:40 Europe/Paris] PHP Fatal error:  Maximum execution time of 30 seconds exceeded in C:\Outils\www\projeqtor\model\persistence\SqlElement.php on line 34
[18-Jan-2021 14:41:40 Europe/Paris] PHP Fatal error:  Maximum execution time of 30 seconds exceeded in C:\Outils\www\projeqtor\tool\projeqtor.php on line 45
[18-Jan-2021 14:41:40 Europe/Paris] PHP Fatal error:  Maximum execution time of 30 seconds exceeded in C:\Outils\www\projeqtor\tool\html.php on line 30
Do you have any idea ?
23 Jan 2021 11:15 #2 by babynus
Replied by babynus on topic new project impossible
You move to V8.5.4 ?
Or you moved from V8.5.4 to newest ? Then to which ?
First check your migration process...
Did you overwrite existing code with new one as advised ?
Did you have any technical change with migration ? Server change, upgrade PHP version, or any other technical migration ?
It is always a bad idea to have technical migration (change technical software versions or else) with functional migration (change version of projeqtor) as you would never know when issues come from.
Good step is : operate technical migration, with same projeqtor version. Run for few days or weeks to ensure new platform is correct.
Then migrate projeqtor.
