ProjeQtOr free project management software - Issue with Deleting custom field via screen customization plug-in - ProjeQtOr
05 Feb 2021 02:02 #1 by PBexpress
Also now can't search for documents anymore I imagine the problems are linked. Attached is the error log, I would be happy to give anyone a log in that could help.
05 Feb 2021 21:39 #2 by babynus
Which version of Screen Customization plugin are you using ?
First try and create field idProduct on Document.
It seems your update removed it.
This is possibly using an old versionh of Screen Customization.
If this does not fix the issue, please post here file model/cutom/Document.php
06 Feb 2021 02:02 - 06 Feb 2021 02:05 #3 by PBexpress
I attached the document.php
I tried to create a product Id and it said already existing. I went ahead and reinstalled the latest screen customization plug in 5.3. Which made where I can't make custom lists now for some reason. If it would be easier to start with a clean install let me know. Attached is what I see on the screen customization screen now, the dddd will not delete for some reason.
Thanks for your help
File Attachment:
File Name: Document.php.zip
File Size:2 KB
Last edit: 06 Feb 2021 02:05 by PBexpress.
06 Feb 2021 12:19 #4 by babynus
Clean browser cache
There is no major issue on your file, except ddcode references a non existing db field.
This can happen if you restored a DB without the field or copied customization from one instance to the other.
To avoid errors, just comment line
  public $idDdcode;
like this
​​​​​​​  // public $idDdcode;
