ProjeQtOr free project management software - The sort order of each test case isn't copied while copying a whole test session - ProjeQtOr
18 Feb 2021 19:00 - 18 Feb 2021 19:30 #1 by pakkes
Hello. In first, I want to congratulate you on your wonderful software.
I've found a strange behavior while copying a whole test session. My will was to duplicate a test session and run it again to verify if my colleague have fixed a couple of bugs on our RFID reader. I would expect to get the same sort order of test cases, but the sort order is zero on the copied session.
I attach 2 screenshots where you can see the sort order of first and second (copied) session.
Of course it's not a problem to manually sort a few test cases; however it would be a problem to manually sort dozens of test cases while testing for example the new release of a complex software.
Last edit: 18 Feb 2021 19:30 by pakkes.
22 Feb 2021 20:10 #2 by babynus
Issue recorded as Ticket #5318
23 Feb 2021 00:54 #3 by pakkes
Really many thanks for taking care about this bug.
