ProjeQtOr free project management software - [SOLVED] Menu overlay in Projeqtor 9.1.4 on edge - ProjeQtOr
21 May 2021 17:35 #1 by rakoun
I juste update to Projeqtor 9.1.4.
There is a menu overlay.
Step to reproduce:
1) disconnect from your session
2) connect to a new session
3) in left menu pan, select menu item "Report"
4) report menu items overlay with default menu items
22 May 2021 00:13 #2 by mkavurcic
The following user(s) said Thank You: Arkhanje
25 May 2021 12:07 #3 by Flou
Clean your browser, it should be better after
25 May 2021 15:29 #4 by rakoun
Flou post=30411 wrote: Clean your browser, it should be better after
ok thanks it works now.
