ProjeQtOr free project management software - V9.2.0 Notification definition: undefined class name index - ProjeQtOr
30 Jun 2021 11:37 #1 by yalovali
Problem occurs when I want to define a notificatoion definition for an opportunity. It gives the error:
ERROR : An error occurred on 2021-06-30 at 12:31:10
On the log side, I got line:
2021-06-30 12:20:48.391 ***** ERROR ***** [V9.2.0] ERROR *****
2021-06-30 12:20:48.391 ***** ERROR ***** [V9.2.0] on file '/var/www/html/model/NotificationDefinition.php' at line (1314)
2021-06-30 12:20:48.391 ***** ERROR ***** [V9.2.0] cause = Undefined index: Opportunity_id
On php side, (with a line of mine to see the objClass Keys)
  1314         errorLog('Keys:'.implode(',',array_keys($objClass)));   <---- MY LINE TO SEE KEYS
  1315         $notif->notifiedObjectId = $objClass[$className.'_id'];^M
It seems like an upper/lower case problem. But I am reluctant to touch more php code, i am not that qualified with php... :)
2021-06-30 12:31:10.421 ***** ERROR ***** [V9.2.0] Keys:opportunity_id,opportunity_initialenddate,opportunity_iduser
2021-06-30 12:31:10.421 ***** ERROR ***** [V9.2.0] ERROR *****
2021-06-30 12:31:10.421 ***** ERROR ***** [V9.2.0] on file '/var/www/html/model/NotificationDefinition.php' at line (1315)
2021-06-30 12:31:10.421 ***** ERROR ***** [V9.2.0] cause = Undefined index: Opportunity_id
02 Jul 2021 11:24 #2 by babynus
I cannot reproduce.
Are you using MySql or Postgres ?
Could you post screenshot of the notification definition you try and insert ?
02 Jul 2021 13:49 #3 by yalovali
My database is postgresql.
About the ticket i have opened, while trying to repeat it for you i figured out that, it repeats only if RULE is empty.
So I think it is my misuage of the screen.
Any way, the related logs when rule field is empty, are as follows:
2021-07-02 14:34:51.942 ***** ERROR ***** [V9.2.0] ERROR *****
2021-07-02 14:34:51.942 ***** ERROR ***** [V9.2.0] on file '/var/www/html/model/NotificationDefinition.php' at line (1314)
2021-07-02 14:34:51.942 ***** ERROR ***** [V9.2.0] cause = Undefined index: Opportunity_id
ENTER SOMETHING AS RULE, and no log is created.
08 Jul 2021 15:30 #4 by babynus
Still cannot reproduce but I think I found a fix.
Will be deployed on V.9.2.2
