ProjeQtOr free project management software - [SOLVED] CRON not starts How to solve the error? - ProjeQtOr
05 May 2022 07:36 #1 by chandrashekhar
Hi Expert,
Hope you are doing well
I have just upgraded ProjeQtOr Version as shows in the attachment & started CRON, but it's not starting & giving an error. Please refer error & all other related details in attached file. Please help me to solve this.
05 May 2022 11:53 #2 by babynus
I think PHP user hasn't right to write in folder projeqtor/files/cron
05 May 2022 13:25 #3 by chandrashekhar
Thanks for reply. I think you can help me through check following ERROR lines in ProjeQtOr log file.
2022-05-05 10:40:26.544 ***** ERROR ***** [V9.5.3] ERROR *****
2022-05-05 10:40:26.545 ***** ERROR ***** [V9.5.3] on file 'D:\projeqtor\projeqtorV9.4.2\projeqtor\model\Cron.php' at line (118)
2022-05-05 10:40:26.545 ***** ERROR ***** [V9.5.3] cause = fopen(e:\projeqtor-wamp\cron/DELAYS): failed to open stream: No such file or directory
2022-05-05 10:40:26.546 ***** ERROR ***** [V9.5.3] fopen(e:\projeqtor-wamp\cron/DELAYS): failed to open stream: No such file or directory in Cron.php at line 118
2022-05-05 10:40:26.546 ***** ERROR ***** [V9.5.3] Error while executing CRON script : fix the source issue and manually restart the CRON Process
Can you help me to know file name from when fopen gets path? I think, it will be solved my issue through edit that path.
05 May 2022 14:05 #4 by chandrashekhar
I have got the solution by checking in automation tab in global parameter.
Thanks for your continuous support.
