ProjeQtOr free project management software - Input mailbox for Tickets does not list all entries - ProjeQtOr
14 Oct 2022 15:37 #1 by iangoing
When adding multiple entries for the Input mailbox for Tickets screen, some records are not visible - but are in the database, as new records can't be saved if the Project has already been used.
How can I get these records to be visible?
14 Oct 2022 16:11 #2 by babynus
Maybe its because you applied filter or don't have rights to see tickets on thie project.
Do you see other tickets on the target projects ?
17 Oct 2022 09:44 #3 by iangoing
The issue was that the record was being closed automatically because the imap string failed. There was a notification generated - but I hadn't seen it. because you have to actively go in to the Notifcations form to see them.
I'm still learning about ProjeQtOr - so apologies for not checking fully.
Also, I solved the IMAP string issue - so it's all good now. But just so I don't spend lots of time looking around in the settings - is it also possible to create Questions from emails, in a similar fashion? Or maybe a ticket can be transferred to a question?
27 Oct 2022 11:30 #4 by babynus
No, only Tickets
Wes, you can easily copy a ticket into a question
