ProjeQtOr free project management software - [SOLVED] One project ans its activies blocked (v10.1.2) - ProjeQtOr
15 Feb 2023 15:52 #1 by c.gallois
Hello, I have a project blocked for all fields, withn "en cours" status. 2 activities of this project blocked in "en cours" status without any other choice in the dropdown list.
Workflow is OK, I have admin privileges.
Probably issues in time sheets or work in tickets.
Thanks for helping!
18 Feb 2023 18:00 #2 by babynus
Sorry but I really don't understand your "issue".
"project blocked" : what is it ?
Please explain.
Maybe some screen shots...
20 Feb 2023 10:42 #3 by c.gallois
I have no possibility to change any project information (All fields in grey, status "en cours").
Project's activities in "en cours" status, unable to change status. Best regards
20 Feb 2023 11:55 #4 by babynus
Check the flag "idle", it may be checked whatever the status (may be checked from parent if user has "force close" specific right)
20 Feb 2023 12:28 #5 by c.gallois
I will close all tickets linked to activities, then I will try to close activities if possible and see effects on the project where all fiels are in grey.
20 Feb 2023 16:30 #6 by c.gallois
Eventually:
Planning view: project & 1 activity locked.
Impossible to close 1 activity because work remaining.
Validation of timesheet doesn't register the work enabling to close the activity (message: "unable to close item with work to do")
Best regards
