ProjeQtOr free project management software - Reports/Costs/Resource costs per month => error message - ProjeQtOr
07 Jun 2023 16:35 #1 by LaurentC
Got the following error with "resource cost per month" report:
2023-06-07 16:24:22.067 ***** ERROR ***** [V10.3.4] ERROR *****
2023-06-07 16:24:22.067 ***** ERROR ***** [V10.3.4] on file 'D:\xampp7\htdocs\projeqtor\report\headerFunctions.php' at line (81)
2023-06-07 16:24:22.067 ***** ERROR ***** [V10.3.4] cause = Invalid characters passed for attempted conversion, these have been ignored
09 Jun 2023 16:41 #2 by babynus
It seems some of your project have a Color that is not in Hexadecimal format (#XXYYZZ where XX, YY and ZZ are hexadecila values).
This should not happen if color is defined through project screen.
It may happen if color is defined through import or API (or direct DB update, but I hope you did not do that )
Check colors for your project.
Please fix any invalid format or report any valid format that generates the issue.
12 Jun 2023 11:08 #3 by LaurentC
Hi & thanks for feedback.
Any idea of potentially impacted table ?
Best regards
#L.
12 Jun 2023 11:44 #4 by babynus
Table Project.
The following user(s) said Thank You: LaurentC
12 Jun 2023 16:38 #5 by LaurentC
Problem fixed. Thanks a lot.
(root cause, direct modif in the database... I will copy 1000 times "I must not ..."
