ProjeQtOr free project management software - I cannot delete a project - ProjeQtOr
26 Jun 2023 16:55 - 26 Jun 2023 16:56 #1 by lhullebr
I created a project instead of an activity.
I'm trying to delete tthis project to create the activity but I'm not able to do it.
Please find attached the copy of the screen and the message that I receive.
Last edit: 26 Jun 2023 16:56 by lhullebr.
26 Jun 2023 17:10 #2 by Plucks
Replied by Plucks on topic I cannot delete a project
Does your profile allow you to modifiy or delete a project ?
You can check what your profile is on the user parameters menu (on the top right).
For instance, here, it is "Administrator"
Then, on the "Access to data (project dependant)" screen ( in Configuration/Access Rights), check what your profile can do with "Projects".
Here, the administrator is "manager+" meaning he can delete all elements in all projects.
26 Jun 2023 17:16 #3 by lhullebr
Replied by lhullebr on topic I cannot delete a project
I'm already admin but for the project I'm supervisuer and I cannot modify either this
26 Jun 2023 17:18 #4 by lhullebr
Thank you. I've changed my data access for superviseur.
26 Jun 2023 17:27 - 26 Jun 2023 17:27 #5 by Plucks
Indeed, when you're allocated to a project with a profile "lower" than your default profile (in your case, from Admin to Supervisor), then you get the rights of the profile you have on this project.
Just a side note : it might be better in such a case to change your allocation on this project (for yourself only) to be an "Admin", instead of a Supervisor (and then, be able to delete the project, as you wanted to do).
If you change data access for Supervisor, please take into consideration that you now allow every Supervisor to delete their projects. Just be sure it's what you want to do.
Last edit: 26 Jun 2023 17:27 by Plucks.
