ProjeQtOr free project management software - Problem about Copy project - ProjeQtOr
08 Feb 2012 10:03 #1 by greg35
We have found a problem when we copy a project
To reproduce this bug follow the next steps :
- Create a new project with a name project1 and a type template
- Create the activities
- Add a new activity with a name "activitySon" and project name "project1"
- Add a new activty with a name "activityFather" and project name "project1"
- Edit the activity "activitySon" and set activity parent to "activity father"
- Goto projects, select the project1 and click on copy project, for the destination project name set project2
As result on the copy we have,
The activity name "activityFather" is on project2 but the activity "activitySon" is on project1 instead of to have a link to the project2.
Best regards.
08 Feb 2012 16:41 #2 by babynus
This issue should be fixed in V2.0.0
If you are using V1.9.1 (or less) I should advise you to migrate to V2.0.0.
If you are using V2.0.0, reply to this post so that I will investigate further.
08 Feb 2012 17:09 #3 by greg35
Thanks you for you reply.
I use the 2.0.0 version.
I can send you a partial bug fix (see below).
The problem is on the copyProjectTo.php, currently the activities are iterated on id field.
Parent activity should not be migrated to the new project when the current activity is saved. A validation error is done in save method and the current activity isn't moved to the new project.
To fix the problem, activities must be ordered by wbsSortable field and not by id field. Navigation tree was done from parent activities to sons activities . The parent activities are moved and saved; then sons activities aremoved and saved. No validation errors occured.
Below the svn patch.
The last problem to resolve: sons activities order in the final project are not saved in the same order as parent. The activiy copy (in foreach statement, line 46) is the problem. It was done on an array sorted by id but not by wbs.
Index: copyProjectTo.php
--- copyProjectTo.php    (revision 450)
+++ copyProjectTo.php    (working copy)
@@ -41,12 +41,17 @@
     // Copy activities
   $activity=New Activity();
   $activities=$activity->getSqlElementsFromCriteria($crit, false, null, null, true);
   foreach ($activities as $activity) {
       $act=new Activity($activity->id);
     $new=$act->copy();
     $actArrayObj[$new->id]=$new;
     $actArray[$activity->id]=$new->id;
+  // Sort by wbsSortable
+  usort($actArrayObj, "customSortByWbsSortable");
     foreach ($actArrayObj as $new) {
         //$new=new Activity($new->id);
         //$new->name='Copied ' . $new->name;
@@ -139,4 +144,12 @@
 } else {
   echo '<span class="messageWARNING" >' . $result . '</span>';
+function customSortByWbsSortable($a,$b) {
+    if (strlen($a->ActivityPlanningElement->wbsSortable) == strlen($b->ActivityPlanningElement->wbsSortable) ){
+        return $a->ActivityPlanningElement->wbsSortable > $b->ActivityPlanningElement->wbsSortable;
+    }else {
+        return $a->ActivityPlanningElement->wbsSortable < $b->ActivityPlanningElement->wbsSortable;
\ No newline at end of file
Best regards
09 Feb 2012 18:44 #4 by babynus
Thnaks for bug fix (even if partial)
Will be implemented / completed in next patch release.
10 Feb 2012 08:59 #5 by greg35
Thank you for you reply.
Have you open a bug ?
And if yes, can you send me the number to follow the fix.
10 Feb 2012 18:25 #6 by babynus
Ticket #560.
