ProjeQtOr free project management software - How to export / import & replace assigments? - ProjeQtOr
05 Dec 2023 08:50 #1 by loicr
Gantt planning report was created by loicr
Dear,
When i try to have reports ( Gantt planning ) and select main projet i've got red box with :
ERROR : foreach() argument must be of type array|object, null given
   in jsonPlanning_pdf.php
   at line 359
log :
2023-12-05 08:45:59.395 ***** ERROR ***** [V11.0.2] ERROR *****
2023-12-05 08:45:59.395 ***** ERROR ***** [V11.0.2] on file '/var/www/projeqtor/tool/jsonPlanning.php' at line (947)
2023-12-05 08:45:59.396 ***** ERROR ***** [V11.0.2] cause = foreach() argument must be of type array|object, null given
2023-12-05 08:46:04.124 ***** ERROR ***** [V11.0.2] ERROR *****
2023-12-05 08:46:04.124 ***** ERROR ***** [V11.0.2] on file '/var/www/projeqtor/tool/jsonPlanning.php' at line (947)
2023-12-05 08:46:04.125 ***** ERROR ***** [V11.0.2] cause = foreach() argument must be of type array|object, null given
2023-12-05 08:46:25.453 ***** ERROR ***** [V11.0.2] ERROR *****
2023-12-05 08:46:25.454 ***** ERROR ***** [V11.0.2] on file '/var/www/projeqtor/tool/jsonPlanning.php' at line (947)
2023-12-05 08:46:25.454 ***** ERROR ***** [V11.0.2] cause = foreach() argument must be of type array|object, null given
2023-12-05 08:46:29.910 ***** ERROR ***** [V11.0.2] ERROR *****
2023-12-05 08:46:29.910 ***** ERROR ***** [V11.0.2] on file '/var/www/projeqtor/tool/jsonPlanning_pdf.php' at line (359)
2023-12-05 08:46:29.910 ***** ERROR ***** [V11.0.2] cause = foreach() argument must be of type array|object, null given
If i select single project, it was working yesterday, but emplty screen today : nothing.
LR
05 Dec 2023 11:05 #2 by Arkhanje
Replied by Arkhanje on topic Gantt planning report
Check your resource. There is apparently a problem with an unnamed resource on the project to display.
We are working on a patch for the next version
05 Dec 2023 11:20 #3 by loicr
Replied by loicr on topic Gantt planning report
I cheched and add name for all ressources and user but it seems to be the same.
05 Dec 2023 11:22 #4 by Arkhanje
after reboot and clear cache? we never know ?!
05 Dec 2023 11:27 #5 by babynus
Replied by babynus on topic Gantt planning report
You can try and add initals to your resources or change display for resources to names instead of initials.
This will avoid the code that generates the error as it occurs when generating initials from name.
05 Dec 2023 11:34 #6 by loicr
reboot done and cache clear ... all is the same !!!
nothing happen when i click on view and if i click on pdf :
red box with
at line 359
I try with "initial" on all resources (one missing) , view alway display nothing but pdf work on some project but not all some with red display
LR
