ProjeQtOr free project management software - Error at real work input - ProjeQtOr
10 Sep 2024 16:55 #1 by fsobel
with projeqtor V11.3.1, when, as a supervisor, I try to input real work on an "in progress" activity assigned to my "project manager" ressource that occured last week, an error occurs which is translated into the log file as below. Any hint why it occurs ?
Cdlt/BR/Mfg
Frank2024-09-10 16:14:10.315 ===== TRACE ===== WARNING - Left work not retrieved from screen
2024-09-10 16:14:10.315 ===== TRACE ===== - Maybe max_input_vars is too small in php.ini (actual value is 4000)
2024-09-10 16:14:10.315 ***** ERROR ***** [V11.3.1] ERROR *****
2024-09-10 16:14:10.315 ***** ERROR ***** [V11.3.1] on file '/var/www/html/tool/saveImputation.php' at line (40)
2024-09-10 16:14:10.315 ***** ERROR ***** [V11.3.1] cause = Error - Maybe max_input_vars is too small in php.ini
2024-09-10 16:15:08.728 ===== TRACE ===== WARNING - Left work not retrieved from screen
2024-09-10 16:15:08.728 ===== TRACE ===== - Maybe max_input_vars is too small in php.ini (actual value is 4000)
2024-09-10 16:15:08.729 ***** ERROR ***** [V11.3.1] ERROR *****
2024-09-10 16:15:08.729 ***** ERROR ***** [V11.3.1] on file '/var/www/html/tool/saveImputation.php' at line (40)
2024-09-10 16:15:08.729 ***** ERROR ***** [V11.3.1] cause = Error - Maybe max_input_vars is too small in php.in
12 Sep 2024 09:36 #2 by Arkhanje
Replied by Arkhanje on topic Error at real work input
The message indicates that the max number of variables in php of your server that it can process simultaneously.
Try to modify the php.ini file to increase this value, otherwise some ProjeQtOr scripts might not pass.
by default, it is at 1000, try to pass it to 5000 to see if the problem persists
