ProjeQtOr free project management software - [SOLVED] Cron script issue - ProjeQtOr
23 Apr 2025 07:24 - 23 Apr 2025 07:34 #1 by nhedhili
Cron script issue was created by nhedhili
we mopoved to version 12.1.1 the cron stops more frequentlty in this version for us.
we were using the cron script ( the standard cron script provided here in the forum ) to activate the cron automatiquely when it stops. We noticed that in this version the cron script does not work any more and it sends the flolowing error ( image file joined ).
Thank you for your help and assistance.
Last edit: 23 Apr 2025 07:34 by nhedhili.
23 Apr 2025 11:44 #2 by babynus
Replied by babynus on topic Cron script issue
We did not change anything on the part of code (headerFunctions.php, line 108)
Reading issue you face, I guess taht you not only migrated to new projeqtor version, but you also upgraded PHP version.
So this may be new restriction on new PHP version.
We'll fix this
26 Apr 2025 07:48 #3 by nhedhili
Replied by nhedhili on topic Cron script issue
Thank you for your reply.
Do you need the actual version of PHP on which we are working ?
04 May 2025 00:44 #4 by babynus
Issue is fixed.
Available through subscription service
06 May 2025 18:52 #5 by nhedhili
thank you
16 May 2025 10:45 #6 by nhedhili
The problem is when the script call Projeqtor APIs (Cron/check and Cron/start)  using this URL https://projeqtor_host/projeqtor/api/index.php?uri=Cron/check, we got error 302 from the apache server as mentionned below:
[auth_basic:error] [pid 3037303] [client 37.60.228.139:43642] AH01617: user projeqtor_cron: authentication failure for "/projeqtor/api/index.php": Password Mismatch
The user is created on projeqtoria and the password is encrypted and defined in .htpasswd and also added into the script for authentication.
The script was working and we didn't change the user credentials but then suddenly we got this authentication failure.
