ProjeQtOr free project management software - max_input_vars=1000 is too small - ProjeQtOr
13 Jul 2025 17:25 #1 by Maurice Faramelli
I just trying to install projeqtor on a Centos 9 server and I get this message max_input_vars=1000 is too small .... php.iniI checked the file which is located under /etc
I modified it to 3000 and tried to reconfigure projeqtor but I get still the same result
I would appreciate any help
Thank you
13 Jul 2025 17:32 #2 by babynus
You ware almost there : expected value is 4000 (or over).
Not that this is just a warning message, projeqtor will work with default value.
The following user(s) said Thank You: Maurice Faramelli
