ProjeQtOr free project management software - Agenda: buttons and selection filters partially hidden - ProjeQtOr
25 Nov 2025 21:48 - 26 Nov 2025 17:37 #1 by LaurentCap
Hello, I use ProjeQt'Or daily with my team. After updating to version 12.3.2, when I display the calendar page, all the buttons and filters on the screen are inaccessible. As a result, we can no longer use the calendar, which is very detrimental to my team. You will find screenshots below to illustrate the issue. With and without the menu list in the attached file.
I use Chrome Version 142.0.7444.176 (Build officiel) (64 bits)
I try on FIREFOX 140.5.0esr (64 bits) and it's the same
 Thank you for your help.
Last edit: 26 Nov 2025 17:37 by LaurentCap. Reason: Problem with image paste
01 Dec 2025 10:44 #2 by maxca
Is your browser zoom set to 100%?
Can you tell me your screen resolution?
In the meantime, try lowering your browser zoom to restore the settings.
12 Dec 2025 15:39 #3 by babynus
I guess you did not clear your browser cache
12 Dec 2025 15:52 #4 by LaurentCap
On the contrary, that's the first thing I tried, without success. I even changed browsers with the same result.
In my attempts, I created a new user and found that the display was correct. Could there be a user cache directly linked to the server?
If so, how can I clear it?
12 Dec 2025 16:12 #5 by babynus
Cache on server side : possible but not sure how it works.
You should ask the administrator of your web server.
I would really bet on browser cache : for CSS, sometime F5 or CTRL+F5 is not enough
On Chrome, best is to use CTRL+SHIFT+DEL and clean "Images and files" cache
12 Dec 2025 16:43 - 12 Dec 2025 16:45 #6 by LaurentCap
I try CTRL+SHIFT+DEL and clean "Images and files" cache from the beginning follow up by close/open chrome with no success.
Help  .
That's why I thinked the problem is on the server side.
Last edit: 12 Dec 2025 16:45 by LaurentCap.
Time to create page: 0.083 seconds
