ProjeQtOr free project management software - Work command: Billed is no longer calculated - ProjeQtOr
09 Feb 2026 18:00 - 09 Feb 2026 18:06 #1 by sgodde
 Hi
Version: 12.3.3
Order created with Work command: Order.jpg
- Order in “in progress” status
We have an activity in the OU catalog, which is linked to the Work command: Activity.jpg
- Activity in "validated" status
the customer invoice indicates the table: Billed work order: invoice.jpg
- Billed in "validated" status
- the invoice and the order are linked
Problem: the sum of the invoiced amount in the "Billed work order" table is zero. ==> Why?
- We tried using the new "Acceptance" menu, but it doesn't change anything.
- it worked correctly before with version 11
Sébastien
Last edit: 09 Feb 2026 18:06 by sgodde.
09 Feb 2026 18:10 #2 by sgodde
In addition:
The "Total" row is not aligned with the different columns of the table
21 Feb 2026 19:23 #3 by babynus
This issue is already fixed.
I think fix is available in V12.4.2
