ProjeQtOr free project management software - Problem with IE8 - ProjeQtOr
Problem with IE8
16 Feb 2012 14:01 - 16 Feb 2012 14:11 #1 by jmmbb
Problem with IE8 was created by jmmbb
I'm using IE8 and Firefox 10.
With IE8 (official browser in the office), making a change in activities, leads to freeze activity screen. It was impossible to select another activity, you must quit IE8, flush the cache and reconnect.
Here is the error reported by IE8 :
Détails de l’erreur de la page Web
Agent utilisateur : Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Trident/4.0; InfoPath.1; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MS-RTC LM 8; .NET4.0C; .NET4.0E)
Horodateur : Thu, 16 Feb 2012 12:59:12 UTC
Message : Cet objet ne gère pas cette action.
Ligne : 1102
Caractère : 2
Code : 0
URI : [url]http://.../view/js/projector.js[/url]
16 Feb 2012 16:17 #2 by Sébastien
Replied by Sébastien on topic RE : Problem with IE8
I have the same issue with IE 8 on my projectorria version and reproduced it on projectorria demo.
When I perform an create or update or delete action, I can't do anything else, I need to disconnect and reconnect, there seems to be a javascript issue. this is what I get :
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727)
Timestamp: Thu, 16 Feb 2012 15:16:05 UTC
Message: Object doesn't support this action
Line: 1102
Char: 2
Code: 0
URI: http://localhost:8080/projectorria/view/js/projector.js
Sébastien
16 Feb 2012 17:48 #3 by babynus
Replied by babynus on topic RE : Problem with IE8
Isuue confirmed ...
Registered as ticket #575...
and fixed.
I had to unactivate row selection after update on IE8 (it's an IE8 specific bug).
So, on IE8, after update, no row will be selected in the list grid (same behavior as prior to V1.9).
17 Feb 2012 08:17 #4 by Sébastien
Thanks a lot, does it mean the version 2.0.0 available for download has the bug fixed?
17 Feb 2012 10:05 #5 by babynus
No,
V2.0.1 will soon be deployed.
17 Feb 2012 13:45 #6 by Sébastien
Great thanks. :D
