ProjeQtOr free project management software - Error when saving RealWorkAllocation - ProjeQtOr
27 Feb 2012 14:07 #1 by rdevau
Dear All,
I have the same issue as spiderjn (topic #475)
We use v1.9.0
I checked the parameter dvVersion: dbVersion | V1.9.0
And when users want to save imputation, I get:
2012-02-27 13:49:28 ***** ERROR ***** ERROR *****
2012-02-27 13:49:28 ***** ERROR ***** on file '/var/www/project/projectorria/tool/saveImputation.php' at line (15)
2012-02-27 13:49:28 ***** ERROR ***** cause = Undefined index: nbLines
Do you have any feedback about this?
Need more logs or informations, ask me!
Best Regards,
Rémi
27 Feb 2012 15:43 #2 by babynus
Very strange.
I never produced this issue.
Can you try to replace in /model/ImputationLine.php, line 543
if (! $print) {
      echo '<input type="hidden" id="nbLines" name="nbLines" value="' . $nbLine . '" />';
with
if (1) {
27 Feb 2012 16:18 #3 by rdevau
Thanks for the feedback,
Same result (in v1.9.0, this is the line 481).
Need more log/info?
Rémi
28 Feb 2012 15:28 #4 by babynus
Can you please try to replace same lines with
if (! $print) {
      echo '<input type="text" id="nbLines" name="nbLines" value="' . $nbLine . '" />';
Then go to Real Work Allocation, and send me print screen (bottom of screen is important : there should be a new "not formated" field.
28 Feb 2012 15:50 #5 by rdevau
Yes, I can see the text box with a good value... please see the screenshot on the following link...
postimage.org/image/p9vs1b6pp/
And with the original code, i get the correct data too...
<input id="nbLines" type="hidden" value="59" name="nbLines">
<input id="nbLines" type="text" value="59" name="nbLines">
The whole form block:
<form id="listForm" dojoattachevent="onreset:_onReset,onsubmit:_onSubmit" dojoattachpoint="containerNode" action="" method="post" widgetid="listForm" style="width: 1279px; height: 294px;">
<input id="userId" type="hidden" value="25" name="userId">
<input id="rangeType" type="hidden" value="week" name="rangeType">
<input id="rangeValue" type="hidden" value="201209" name="rangeValue">
<input id="idle" type="checkbox" style="display: none;" name="idle">
<input id="showPlannedWork" type="checkbox" style="display: none;" name="showPlannedWork">
<input id="page" type="hidden" value="../report/imputation.php" name="page">
<input id="outMode" type="hidden" value="" name="outMode">
<table class="imputationTable">
</form>
28 Feb 2012 15:55 #6 by babynus
Ist it really the whole form block ?
the <table class="imputationTable"> should include much more data...
