ProjeQtOr free project management software - Problem with the export MS Project XML - ProjeQtOr
09 Mar 2012 14:17 #1 by ydavid
I want to create an export of the planning in the format MS-Project XML. But, when I try to import it to MS-Projet, it isn't possible.
The error is : MS Project Unexpected Problem opening the file.
09 Mar 2012 14:44 #2 by babynus
The format is MS-XML, so you have to open it as import not as standard mpp.
09 Mar 2012 16:40 - 09 Mar 2012 16:42 #3 by ydavid
So, how can I open the export MS-Project XML, create thanks to Project'or, in MS Project?
09 Mar 2012 17:10 #4 by babynus
Open MS-Project.
File / Open
Change File Type to : XML.
Select exported file (without renaming it)
Click Open.
Import as new Project.
Done ! ;)
12 Mar 2012 10:12 #5 by ydavid
babynus wrote: Open MS-Project.
File / Open
Click Open.
Done ! ;)
But I have the problem at this moment.
12 Mar 2012 10:35 #6 by babynus
If your data is not confidential (or you can anonymyse it), maybe you can sent your file to This email address is being protected from spambots. You need JavaScript enabled to view it. for analysis.
