ProjeQtOr free project management software - Troubles with IE7 - ProjeQtOr
Troubles with IE7
19 Jul 2012 22:00 #1 by Hammurabi
Troubles with IE7 was created by Hammurabi
Hello Babynus,
I have some troubles with IE7 : i can't not connect to the main menu in IE7, connexion is accepted but the screen of loging is frozen.
I think is about the javascript module. what do u think ?
Thx
19 Jul 2012 22:31 #2 by babynus
Replied by babynus on topic Re: Troubles with IE7
Sorry, I cannot test on IE7, I don't have any workstattion with this version anymore.
Which version of Project'Or RIA ?
Did you try and refresh the browser cache ?
Can you report any Javascript error ?
19 Jul 2012 22:41 - 19 Jul 2012 22:44 #3 by Hammurabi
Replied by Hammurabi on topic Re: Troubles with IE7
- I'm using the last version (2.4)
- Yes, i refresh the browser cash
- I don't how to catch the error on IE 7
By the way, i have the same trouble with FirexFox 14 ... it works perfect with the version 2.1.1 but not now ... And, i'm testing in my work environnement so do u think that the security restrictions can provoque this problem ?
Thx
Last edit: 19 Jul 2012 22:44 by Hammurabi.
19 Jul 2012 23:09 #4 by babynus
I just tested on Firefox 14, it's working correctly.
So you may have an issue on your deployment of the new version.
To get the Javascript error (if any), open the console on Firefox : [shift]+[ctrl]+J
Maybe you can try and re-install.
20 Jul 2012 14:26 #5 by Hammurabi
it works now on FF14 but the problem still persist on IE7 ...
20 Jul 2012 15:11 #6 by ekolossov
Replied by ekolossov on topic Re: Troubles with IE7
Upgrade to IE9
