ProjeQtOr free project management software - BUG: check/uncheck checkbox is not shown? - ProjeQtOr
11 Feb 2011 04:59 #1 by Guest
In the activity page, when I try to check or uncheck the handled, done, closed checkbox.
It just doesn't show as I expect. Only after I save it, the check/uncheck displays as I expect.
Please help to check this issue.
Thanks. :)
Best Regards,
Selina
11 Feb 2011 10:37 #2 by babynus
Could you describe your issue a bit more ?
What did you expect to see ?
Could you describe your test case step by step ?
14 Feb 2011 04:11 #3 by Guest
The problem is a display issue.
For example, I add an activity #1 as recorded, then I change the status to 'assgined' and assign a responsible.
The checkbox of 'handled' is checked automatically as well as the date of 'handled'. I saved it.
So far, there's no problem.
Then I click the checkbox of the 'handled', I expect to see the checkbox is unchecked immediately, but it wasn't.
I don't know if this action is successful or not. But later I saved again. The handled is unchecked of the activity #1.
The 'done' is also the same.
I am confused that the checkbox's checked/unchecked is not display immediately that dispaly only after being saved.
Best Regards,
Selina
14 Feb 2011 11:39 #4 by babynus
It's strange the checkboxes are updated after saving.
In fact if they don't "react" on mouse click, it's because they are locked.
It depends on the parametering : on the "Activity type" parameter you can define that these checkboxes are locked, then they will change only on status change.
Isuue registered as #305 for further analysis.
For information, which browser/version are you using ?
15 Feb 2011 02:11 #5 by Guest
Yes, the lock/done/close handled is checked in my activity type setting. So it shall not update after saving.
My browser is firefox and version is 3.6.13
Best Regards,
Selina
15 Feb 2011 20:27 #6 by babynus
After investigation, it appears to be a known Dojo issue.
This issue shall be corrected in next version of Dojo.
Every try for a workaround got even worse than actual behaviour...
So we'll wait for next version of Dojo.
Maybe if this version is not provided soon, we may revert to Dojo V1.4...
Regards.
