ProjeQtOr free project management software - First installation - OK button doesn't works - Page 2 - ProjeQtOr
17 Sep 2012 14:23 #7 by babynus
Issue confirmed :
- Installation possible without issue on V2.4.x
- Issue on V2.5.x
I'll inveestigate.
Workaround : install V2.4.3.
Then upgrade to V2.5.1.
17 Sep 2012 17:45 - 18 Sep 2012 09:20 #8 by babynus
The issue has been fixed on V2.5.2, that has just been deployed.
If you try to install a brand new instance of Project'Or RIA, get this version.
If you are already running a previous version (V2.4.x or V2.5.1), this fix is no use for you.
Last edit: 18 Sep 2012 09:20 by babynus.
18 Sep 2012 07:53 #9 by pak
Thank you :)
I'm on 2.5.1 now after upgrade my 2.4.3
have a good day
