ProjeQtOr free project management software - Planner not showing 'All Projects' - ProjeQtOr
01 Nov 2012 00:14 #1 by tonyt
Hello.
I just upgraded to version 2.6.3 and everything has been fine so far.
I selected the project from 'All Projects' to a specific one and all is working.
When i select back from my project to 'All projects' the planner does not show anything?
Any suggestions on how i can view all my projects on the planning screen again??
01 Nov 2012 20:08 #2 by babynus
I can nit reproduce this issue.
All is working fine for me.
Can you :
- refresh your browser cache and try again
- check log file for reported error
- check javascript console for any error
- increase "max projects to display" (in global parameters) and try again
- try and run http://youHost/projectorria/tool/jsonPlanning.php and check result
02 Nov 2012 01:43 #3 by tonyt
Thanks babynus.
Looks like it was the "max projects to display" parameter
It would be nice if the alert didnt say "You must select a project" instead saying something like "MAX Projects display exceeded."
Thanks for your help!
02 Nov 2012 11:16 #4 by babynus
Message updated to be more clear
