ProjeQtOr free project management software - Spanish translation - ProjeQtOr
Spanish translation
11 Mar 2013 14:42 #1 by Kantabriko
The Spanish translation is very poor.
I have completed the translation by my own and each time there is a new version I need to check if there is any new label.
Perhaps my translation is not perfect, but it is much better than original (which has a lot of errors and many words without translation).
Here it is my file. Perhaps you think it is a good translation and include it in your next versions.
lang.js
11 Mar 2013 14:43 #2 by Kantabriko
Replied by Kantabriko on topic Re: Spanish translation
The file.
lang.js
11 Mar 2013 14:43 #3 by Kantabriko
How can I attach a file in this forum?
It says: "File is not found"!
11 Mar 2013 15:06 #4 by babynus
Replied by babynus on topic Re: Spanish translation
Thanks for your work.
I'll have a look at it (but I dont't read spanish...)
Click on add file (or just click on the input textbox).
This will open a select file dialog.
Select the file to upload.
Click on new "Insert" button to insert the file in the text.
lang.xls
Submit.
If you don't succeed, you can send it to me at This email address is being protected from spambots. You need JavaScript enabled to view it..
11 Mar 2013 15:08 - 11 Mar 2013 15:08 #5 by babynus
I has same issue.
I think it is due to limitation in extensions.
I try and zip it...
lang.zip
Last edit: 11 Mar 2013 15:08 by babynus.
11 Mar 2013 15:09 #6 by babynus
It is a size limitation :
"Failed to upload file 'lang.zip': The file size (227874) exceeds the maximum set by the administrator."
I'll change it soon.
