ProjeQtOr free project management software - Alerts not working? (yes they do as I learned) - ProjeQtOr
10 May 2013 19:27 - 10 May 2013 19:56 #1 by PerryM
Just installed Project'Or RIA with no problems and am starting to experiment with it.
The first thing I tried was to send an Alert to the employees I set up - doesn't work.
I've searched here and other places and don't see any reference to this problem - so maybe I missed a switch somewhere?
I'm using V3.3.2 Dojo 1.8.0 (29458)
When I click the icon to "create a new alert" I get nothing.
As admin I can send an internal alert from the Administration tab that works just fine - but not from the page I get by clicking the Alert button (!).
Thanks for any help.....
Last edit: 10 May 2013 19:56 by PerryM.
10 May 2013 19:47 #2 by babynus
Replied by babynus on topic Re: Alerts not working?
Could you please check the log for any error.
(by default it is in /files/logs)
10 May 2013 19:50 #3 by babynus
After rereading you post, I thing I misunderstood your issue.
Did you try to create an alert from screen in menu => Tools => Alert ?
Then you got wrong.
This screen only displays generated alerts, and cannot generate a new one.
To test it, you can try in the Administration screen ;)
The following user(s) said Thank You: PerryM
10 May 2013 19:53 #4 by babynus
Also have a look at => Parameters => Controls & Automation => Indicators
It may be what you're looking for. :woohoo:
10 May 2013 19:55 #5 by PerryM
Replied by PerryM on topic Re: Alerts not working?
Thanks much - now I understand...
Time to create page: 0.083 seconds
