ProjeQtOr free project management software - All projects- Ticket view not working in 3.4.0 for some users intermittantly - Page 3 - ProjeQtOr
24 Jul 2013 11:18 #13 by climb4fun
Sorry, have not been as exact: You have to change this in your browsers paramenters, not in Projectorria. :oops:
24 Jul 2013 11:26 - 24 Jul 2013 11:32 #14 by Rexeh
Ok, looks like that does indeed work.
There is of course only one proper English, and that is English UK :P
That is a very strange error, not seen that before.
I will consider this one fixed... but certainly just a workaround until light and be shed on why this happens.
Great find climb4fun
Last edit: 24 Jul 2013 11:32 by Rexeh.
24 Jul 2013 12:05 #15 by babynus
I found the cause of the issue : it is a Dojo regression in V1.9.
The dojo.date.locale.parse fails when time format in 12 hours based (with AM/PM).
Every locale with 24 hours locale works fine.
I so could think of a workaround :
In /view/js/projectorFormatter.js, replace function dateTimeFormatter() with this one :
function dateTimeFormatter(value) {
  if (value && value.length==19) {
  	vDate=dojo.date.locale.parse(value, {datePattern: "yyyy-MM-dd", timePattern: "HH:mm:ss", selector: 'date'});
  	if (! vDate) {
  	  return dateFormatter(value.substr(0,10))+" "+value.substr(11);
    return dojo.date.locale.format(vDate, {formatLength: "short", fullYear: true});
  } else {
  	return value;
The following user(s) said Thank You: climb4fun
24 Jul 2013 12:39 #16 by climb4fun
Hi Babynus,
congratulation, bug is fixed. It works. :woohoo:
Btw. I dismissed all previous bugfix suggestions and made only your suggested workaround (see below).
Thanks,
Klaus
24 Jul 2013 17:39 #17 by babynus
I tested with Dojo 1.9.1 : issue persist.
I opend a Ticket in Dojo bug Tracker : #17342.
I found another fix which is still better than previous, as it preserves expected timle format:
  	vDate=dojo.date.locale.parse(value, {datePattern: "yyyy-MM-dd", timePattern: "HH:mm:ss", selector: 'date and time'});
  	if (! vDate) {
  	  vDate=new Date(value.substr(0,4),value.substr(5,2),value.substr(8,2),value.substr(11,2),value.substr(14,2),value.substr(17,2),0);
  	  if (! vDate) {
  	    return dateFormatter(value.substr(0,10))+":"+value.substr(11,5);
  } else {
  	return value;
function timeFormatter(value) {
  if (value.length==19) {
  	if (! vDate) {
    	if (! vDate) {
    	  return value.substr(11,5);
    return dojo.date.locale.format(vDate, {formatLength: "time"});
  } else {
  	return value;
This fix will be included in V3.4.1
