ProjeQtOr free project management software - Problem with reply to automatic email sent module - ProjeQtOr
28 Jul 2013 22:10 #1 by lowengrin
When i try to configure reply to automatic email module (I follow online projectorria documentation instruction with a gmail account), cron jobs stop unexplained.
I have this problem in 3.4.0 and 3.4.1
Of course, I have tested my imap gmail account before
Thanks for your suggestion.
28 Jul 2013 23:43 #2 by babynus
Do you have any trace in the log file ?
29 Jul 2013 18:25 #3 by lowengrin
Nothing in log files/logs/projector_20130728.log
2013-07-28 21:30:53 ===== TRACE ===== NEW CONNECTED USER 'admin'
here configure mail reply
2013-07-28 21:43:36 ===== TRACE ===== Cron normally stopped at 28/07/2013 21:43:36 2013-
07-28 21:43:48 ===== TRACE ===== Cron started at 28/07/2013 21:43:48
stop/start cron for load "email input check cron delay" parameter at 30 seconds
2013-07-28 21:47:04 ===== TRACE ===== NEW CONNECTED USER 'admin'
2013-07-28 21:47:13 ===== TRACE ===== Cron started at 28/07/2013 21:47:13
I check that cron stop unexplained, unconfigure email reply and restart
In debug mode nothing too
Projectorria 3.4.1/MacOSX (snow leopard)/PHP 5.3.15/Apache 2.2.22
29 Jul 2013 23:53 #4 by babynus
Strange as I just tested again : even with incorrect imap definition, Cron is not stopped, just an error logged.
I propose you to try and get some traces :
- dowload attached file
- upzip it and copy it to replace existing /model/Cron.php
- set logLevl="4" in parameters.php
Run Cron et post log traces here.
30 Jul 2013 15:48 #5 by lowengrin
I have following your instruction.
My cron log in attachment. Is very strange. No ERROR but cron stoppped
30 Jul 2013 16:43 #6 by babynus
Got it :woohoo:
The imap extension is not enabled on your PHP config.
This should be explained is user manual :blush:
