ProjeQtOr free project management software - Get --- Not post - ProjeQtOr
Get --- Not post
12 Nov 2013 20:56 #1 by smashcfr
Get --- Not post was created by smashcfr
It seems that I have a similar issue as described recently on this forum, but with the 3.4.4, not the 4.0.1.
I just uploaded the files of the 3.4.4, and when I try to login to update the software, nothing hapens in Firefox, and in Chromium I have an error message "An error as occured", but nothing more.
If I try to use the Console into Firefox, I see something strange (confirmed by what I see in the url) :
Le formulaire spécifie l'encodage multipart/form-data, mais ne spécifie pas la méthode POST. L'envoi sera plutôt effectué avec la méthode GET et sans spécifier d'encodage.
Could you help me ? What other stuff do you need for this ?
Thank you very much.
12 Nov 2013 22:23 #2 by babynus
Replied by babynus on topic Get --- Not post
This issue appears with WAMP Server.
It it your PHP Server ?
If so, fix will soon be deployed on V4.0.2
If you need a fix for V3.4.4, you can download attached file and unzip in in /tool folder.
12 Nov 2013 22:35 #3 by smashcfr
Replied by smashcfr on topic Get --- Not post
I upladed the file, emptied browser's history, and tried to reconnect.
The "Get" issue has been solved, thank you.
I do not have a xamp server as it is not locally installed (And I think that the servers of my provider are linux servers).
I now have "an error has occured", without more information, and nothing in the Console. I think I will have to have a look at the Apache logs. I will be able to check the real error message tomorrow (The provider gives the logs once a day).
13 Nov 2013 00:10 #4 by babynus
The more likely about the error is an access right on folders where the tool tries to write files.
You may check this with the logs.
13 Nov 2013 08:31 #5 by smashcfr
Thank you.
I checked, and have nothing there this morning : /var/log/apache2.
Strange, because I checked the logs for the subdomain where projeqtor has been installed.
For the right issue, it may be strange too, because I copied the new files at the same place where the old ones were (As I usualy do).
Folders have : drwxr-xr-x
I wonder where to check now... I'll see if I have to activate the logs for the main domain (if possible...).
