ProjeQtOr free project management software - Problem ldap authentication - Page 2 - ProjeQtOr
02 Jan 2014 13:44 #7 by babynus
Replied by babynus on topic Problem ldap authentication
I ran several tests and never could connect witrhout password.
Maybe it is due to your Active Directory configuration, alowing anonymous connections or at least connections without password.
(on my side I use OpenLdap)
I tried with :
incorrect LDAP base DN => error
incorrect LDAP host => error
incorrect LDAP port => error
incorrect LDAP version => error
incorrect LDAP user => error
incorrect LDAP password => error
LDAP filter "uid=%USERNAME%", correct password => login OK (new user created with uid)
LDAP filter "uid=%USERNAME%", incorrect password => "invalid login parameters"
LDAP filter "uid=%USERNAME%", no password => "invalid login parameters"
LDAP filter "cn=%USERNAME%", no password => login OK (new user created with common name)
LDAP filter "cn=%USERNAME%", incorrect password => "invalid login parameters"
LDAP filter "cn=%USERNAME%", no password => "invalid login parameters"
LDAP filter "xx=%USERNAME%", correct password => "invalid login parameters" (no match for filter)
So what you are facing does not seem to be a programming issue.
I guess it is an AD issue : allowing anonymous access or access with no password.
02 Jan 2014 14:18 - 02 Jan 2014 14:19 #8 by babynus
To try and debug, could you please try to :
- download and unzip attached file
- copy this User.php file into /model directory
- set debugLevel="3"
- try again without password
You should retrieve in the log file something like :
2014-01-02 14:12:40
DEBUG
***** trace binding admin *****
2014-01-02 14:12:40
DEBUG
user='cn=Manager,dc=maxcrc,dc=com'
2014-01-02 14:12:40
DEBUG
password='secret'
2014-01-02 14:12:40
DEBUG
binding OK
2014-01-02 14:12:40
DEBUG
result:
2014-01-02 14:12:40
DEBUG
1
2014-01-02 14:12:40
DEBUG
filter=uid=other
2014-01-02 14:12:40
DEBUG
dn=uid=other,ou=People,dc=maxcrc,dc=com
2014-01-02 14:12:40
DEBUG
ldap_user_dn='uid=other,ou=People,dc=maxcrc,dc=com'
2014-01-02 14:12:40
DEBUG
parampassword=''
2014-01-02 14:12:40 ***** ERROR ***** ERROR *****
2014-01-02 14:12:40 ***** ERROR ***** on file 'D:\Programmes\EasyPHP.12.1\www\projeqtor\model\User.php' at line (782)
2014-01-02 14:12:40 ***** ERROR ***** cause = ldap_bind(): Unable to bind to server: Server is unwilling to perform
2014-01-02 14:12:40
DEBUG
result bind user:
2014-01-02 14:12:40
DEBUG
2014-01-02 14:12:40
DEBUG
incorrect binding
Please post your own result here (after hiding password with stars)
Last edit: 02 Jan 2014 14:19 by babynus.
03 Jan 2014 15:08 #9 by soji
Replied by soji on topic Problem ldap authentication
Hello Babynus,
My question is stupid but how to set debugLevel=3 ? :P
03 Jan 2014 15:29 #10 by babynus
In your parameters.php file.
The location of this file is defined in file /tool/parametersLocation.php.
By defaut, it is "../files/config/parameters.php", but it is highly advised to move it outside web access.
The only stupid question is the one that is not asked ;)
06 Jan 2014 10:23 #11 by soji
Hello Babynus,
Here are logs file:
I try to connect with AD account without password: connection successfull
2014-01-06 10:12:28
DEBUG
2014-01-06 10:12:28
DEBUG
user='cn=s_projeqtor,ou=Projeqtor,dc=domain,dc=local'
2014-01-06 10:12:28
DEBUG
password='mypassword'
2014-01-06 10:12:28
DEBUG
binding OK
2014-01-06 10:12:28
DEBUG
result:
2014-01-06 10:12:28
DEBUG
1
2014-01-06 10:12:28
DEBUG
filter=(&(objectCategory=user)(memberof=CN=APP_Projeqtor,OU=Projeqtor,DC=domain,DC=local))
2014-01-06 10:12:28
DEBUG
dn=CN=s_projeqtor,OU=Projeqtor,DC=domain,DC=local
2014-01-06 10:12:28
DEBUG
ldap_user_dn='CN=s_projeqtor,OU=Projeqtor,DC=domain,DC=local'
2014-01-06 10:12:28
DEBUG
parampassword=''
2014-01-06 10:12:28
DEBUG
result bind user:
2014-01-06 10:12:28
DEBUG
1
2014-01-06 10:12:28
DEBUG
***** end trace binding *****
2014-01-06 10:12:28 ===== TRACE ===== NEW CONNECTED USER 'user1'
Then, I try to connect with AD account with password:
2014-01-06 10:19:02
DEBUG
2014-01-06 10:19:02
DEBUG
2014-01-06 10:19:02
DEBUG
2014-01-06 10:19:02
DEBUG
binding OK
2014-01-06 10:19:02
DEBUG
result:
2014-01-06 10:19:02
DEBUG
1
2014-01-06 10:19:02
DEBUG
2014-01-06 10:19:02
DEBUG
2014-01-06 10:19:02
DEBUG
2014-01-06 10:19:02
DEBUG
parampassword='mypassword'
2014-01-06 10:19:02
DEBUG
result bind user:
2014-01-06 10:19:02
DEBUG
1
2014-01-06 10:19:02
DEBUG
2014-01-06 10:19:02 ===== TRACE ===== NEW CONNECTED USER 'user1'
User1 added in user list on Projeqtor but the name is s_projeqtor (it's service account).
06 Jan 2014 12:26 - 06 Jan 2014 12:27 #12 by babynus
The issue is on your filter.
It retrieves exactly the dn of your admin user :
The unexpected behavior is that as you are already connected with this user, the binding with no password works.
It explains why user1 is created with service name (s_projeqtor).
You must define a filter that will retrieve the user that tries to connect, using the %USERNAME% parameter.
("user1" does not appear in the logged filter)
Last edit: 06 Jan 2014 12:27 by babynus.
