ProjeQtOr free project management software - 4.1.1 installation problem. - ProjeQtOr
08 Jan 2014 10:13 #1 by mabartoletti
as soon as i log-in (after the installation process) i have the following error:
ERROR : Invalid access attempt
the log shows:
2014-01-08 08:49:53 ===== TRACE ===== 'user' is not an instance of User class. May be a hacking attempt from IP 192.168.16.45
2014-01-08 08:49:53 ===== TRACE ===== IP CLient=192.168.16.45
2014-01-08 08:49:53 ***** ERROR ***** EXCEPTION *****
2014-01-08 08:49:53 ***** ERROR ***** on file '/var/www/TEST/Shared/vers/projeqtor_4.1.1/tool/projeqtor.php' at line (99)
2014-01-08 08:49:53 ***** ERROR ***** cause = Invalid access attempt
2014-01-08 08:49:53 ***** ERROR ***** => #0 /var/www/TEST/Shared/vers/projeqtor_4.1.1/view/main.php (10) -> require_once()
I have installed (installation ended successfully) projeqtor on a Centos 64 bit with php5.3 .
Doing a bit of debug.. adding echo get_class($user)."<br>"; to projeqtor.php (line 93) i have :
__PHP_Incomplete_Class
can some one help me ?
thanks
08 Jan 2014 11:08 #2 by babynus
Replied by babynus on topic 4.1.1 installation problem.
The most probable is that you retrived PHP session from other application.
Be sure to clean PHP session (clean cookies, remove files in PHP temp directory) and try again.
10 Jan 2014 21:59 - 10 Jan 2014 22:15 #3 by mabartoletti
i clean all caches, session ... (also the server one) but still the same error. It is a problem to istall it under /somedirectory/projects/ ?
here below the print of the object $user:
object(__PHP_Incomplete_Class)#1 (32) { ["__PHP_Incomplete_Class_Name"]=> string(4)
"User" ["_col_1_2_Description"]=> NULL
["id"]=> string(1) "1"
["name"]=> string(5) "admin"
["email"]=> NULL
["password"]=> string(32) "21232f297a57a5a743894a0e4a801fc3"
["_spe_buttonSendMail"]=> NULL
["idProfile"]=> string(1) "1"
["locked"]=> string(1) "0"
["loginTry"]=> string(1) "0"
["isLdap"]=> string(1) "0"
["_spe_image"]=> NULL ["isContact"]=> string(1) "0"
["isResource"]=> string(1) "0"
["initials"]=> NULL
["resourceName"]=> NULL
["idle"]=> string(1) "0"
["description"]=> NULL
["_col_2_2_Affectations"]=> NULL
["_spe_affectations"]=> NULL
["_arrayFilters"]=> array(0) { }
["_arrayFiltersDetail"]=> array(0) { }
["salt"]=> NULL ["crypto"]=> string(3) "md5"
["_accessControlRights":"User":private]=> NULL
["_accessControlVisibility"]=> NULL
["_affectedProjects":"User":private]=> NULL
["_affectedProjectsIncludingClosed":"User":private]=> NULL
["_visibleProjects":"User":private]=> NULL
["_visibleProjectsIncludingClosed":"User":private]=> NULL
["_hierarchicalViewOfVisibleProjects":"User":private]=> NULL
["_hierarchicalViewOfVisibleProjectsNotClosed":"User":private]=> NULL }
hope could be of help.
Last edit: 10 Jan 2014 22:15 by mabartoletti.
11 Jan 2014 01:49 #4 by babynus
No
Issue is that you retrive $user with class __PHP_Incomplete_Class, meaning class cannot be identified.
This happens when session_start() is called before __autoload or called twice.
This is not the case, as projeqtor.php starts with spl_autoload_register, then session_start.
Moreover, application is running fine for most users. So I think you have another application running, with an asynchronous process, that initialises session before the __autoload is defined.
Just to ber sure :
what version or PHP are you running ?
What stack are you running ? (WAMP, Easy PHP, other)
Do you have other applications on same server ? Could you try with projeqtor running alone on a server ?
11 Jan 2014 21:37 #5 by mabartoletti
i know that it is very strange but i do not understand what happen. My configuration is an apache virtualhost and i use the following version of mysql/php/apache on a centos 6 64 bit server:
mysql-5.1.61-1.el6_2.1.x86_64
httpd-2.2.15-15.el6.centos.1.x86_64
php-5.3.3-27.el6_5.x86_64
12 Jan 2014 11:32 #6 by babynus
Do you have other applications on your php server ?
