ProjeQtOr free project management software - Unexpected result on project template copy - ProjeQtOr
28 Jul 2014 11:46 #1 by Plazy31
Hello ,
As I use a lot the same kind of project, I've created a template of this kind :
Main project
- Sub project 1
-- Sub sub project 1
-- Sub sub project 2
- Sub project 2
When i copy the template "main project" I have a result that is unexpected :
- no error on copy
- Main project and all belonging sub projects appears inside the Today window
- Only the Main project appears inside the project window
I was expecting to find inside project window all the sub project.
Is it a bug or am I doing something wrong ?
Thansk for your feed back
Olivier
28 Jul 2014 12:50 - 28 Jul 2014 12:50 #2 by babynus
Does the issue persist after diconnect/reconnect ?
(it may be just a visibility limitation not refreshed dynamically)
Last edit: 28 Jul 2014 12:50 by babynus.
28 Jul 2014 13:33 #3 by Plazy31
Yes the issue persists after disconnect/reconnect
I also try a reboot of my linux server without any changes
28 Jul 2014 13:42 #4 by Plazy31
OK i've found where the issue is :
When you duplicate the template you specifie the project type.
It seems that all sub-projects doesn't inherit the new project type and remain as template
28 Jul 2014 18:25 #5 by babynus
Issue recorded as Ticket #1478
Thanks for the analysis
