ProjeQtOr free project management software - Users are not able to login - ProjeQtOr
31 Jul 2014 07:51 #1 by dhananjaykhalane
We created admin and resource users as per the guide in manual. Whan we loand on the main login page we get this message below the login window and only user with administor is able to login and user with other than administrator not able to login.
Following is the messeage vsibile on main login page.
"Application is closed.
Only admin user can connect.
Please come back later."
Question 1 : How to remove the work in progress logo and above message ?
Question 2 : How to allow users to login to system to start work ?
31 Jul 2014 09:34 #2 by babynus
Replied by babynus on topic Users are not able to login
You just "closed" the application throught administration screen.
Just re-open it through same aplication screen :
=> connect as admin
=> go to Parameters / Administration
=> click on button "open application"
That's all...
The following user(s) said Thank You: dhananjaykhalane
31 Jul 2014 14:05 #3 by dhananjaykhalane
Thanks .....
It works perfectly .....
How do we change the time zone in system ?
I tried to change manually it was not allowing me to login when it as changed to ASIA
31 Jul 2014 14:48 #4 by babynus
in global parameters screen.
Value must fit time zone syntax (mode mouse over the corresponding field for some help)
