ProjeQtOr free project management software - Display of selectable predecessor elements is displayed incorrect - ProjeQtOr
27 Nov 2014 17:33 #1 by BasGobets
In Projeqtor 4.5.1 When I want to add a predecessor to an activity and click on the spyglass to get the full list of possible predecessors the list looks strange (see attached screenshot ) (all dots). The funny thing is that you can still do a search and end up with one line of dots. If that ;line is selected, the correct activity is added as a predecessor.
It thus appears just to be a display problem
27 Nov 2014 19:16 #2 by babynus
Issue confirmed and recorded as Ticket #1622.
It seems to happen when a date exist in the displayed list.
27 Nov 2014 20:01 #3 by babynus
Got it !!!
Wasn't easy to fix, although I found the origin...
To fix :
in /view/js/projeqtor.js, add after last line :
function getBrowserLocaleDateFormatJs() {
 return browserLocaleDateFormatJs;
in /view/js/projeqtorFormatter.js, replace function dateFormatter(), starting line 241, with
function dateFormatter(value) {
  fmt=top.getBrowserLocaleDateFormatJs();
  if (value.length==10) {
  	vDate=dojo.date.locale.parse(value, {selector: "date", datePattern: "yyyy-MM-dd"});
    return dojo.date.locale.format(vDate, {datePattern: fmt,formatLength: "short", fullYear: true, selector: "date"});
  } else {
  	return value;
don't forget to clean browser cahce and test
:woohoo:
The following user(s) said Thank You: BasGobets
28 Nov 2014 09:53 #4 by BasGobets
I implemented the changes and it seems to work!
Thanks for the quick fix
28 Nov 2014 09:57 #5 by babynus
For information, this fix treats "date" fields.
Similar issue has been identified for "date+time" fileds, not fix here.
You can see this for instance listing Tickets (open a ticket and select a dupplicate throught the list).
Patch V4.5.2 fixes both issues.
The following user(s) said Thank You: protion
