ProjeQtOr free project management software - Impossible to connect after the installation - ProjeQtOr
12 Jan 2015 14:11 #1 by MBX
Hi
I've just installed ProjQtor.
When I fill login admin and password admin on the login page, I get the message " Invalid login parameters".
I've found these lines in the logs :
2015-01-12 14:11:17 ***** ERROR ***** Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.user' doesn't exist
2015-01-12 14:11:17 ***** ERROR ***** For query : desc user
2015-01-12 14:11:17 ***** ERROR ***** Strack trace :
2015-01-12 14:11:17 ***** ERROR ***** #0 Sql->query called at [C:\inetpub\wwwroot\PROJEQTOR\model\persistence\SqlElement.php:2146]
2015-01-12 14:11:17 ***** ERROR ***** #1 SqlElement->getFormatList called at [C:\inetpub\wwwroot\PROJEQTOR\model\persistence\SqlElement.php:1908]
2015-01-12 14:11:17 ***** ERROR ***** #2 SqlElement->getDataType called at [C:\inetpub\wwwroot\PROJEQTOR\model\persistence\SqlElement.php:1440]
2015-01-12 14:11:17 ***** ERROR ***** #3 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\PROJEQTOR\tool\loginCheck.php:61]
2015-01-12 14:11:17 ***** ERROR ***** For query : select * from user where user.name='admin' and user.isUser = '1'
2015-01-12 14:11:17 ***** ERROR ***** #0 Sql->query called at [C:\inetpub\wwwroot\PROJEQTOR\model\persistence\SqlElement.php:1473]
2015-01-12 14:11:17 ***** ERROR ***** #1 SqlElement->getSqlElementsFromCriteria called at [C:\inetpub\wwwroot\PROJEQTOR\tool\loginCheck.php:61]
2015-01-12 14:11:17 ===== TRACE ===== Login error for user 'admin'
Thanks for your help.
MB
14 Jan 2015 13:47 #2 by babynus
Try and clean browser cache and try again.
Tell us about the result.
14 Jan 2015 13:55 #3 by MBX
Thanks for your answer :
I cleaned the cache of the browser and retried, but the result is the same : "Invalid login parameters".
I've tried in other browsers too, and I get the same sesult.
14 Jan 2015 16:21 #4 by climb4fun
Hi all,
reading the log file, I saw it didn't find user db. May be database is not set up properly.
Klaus
15 Jan 2015 13:08 #5 by babynus
Which version did you install ?
On which on ?
What is version in /tool/projeqtor.php ? ($version, line 35)
What is version in database ? (value of column parameterValue in table parameter, line with parameterCode='dbVersion')
16 Jan 2015 03:00 #6 by udirect61
