ProjeQtOr free project management software - Requirements - "Product" : empty value when "Project" is filled - ProjeQtOr
05 Feb 2015 01:41 - 05 Feb 2015 01:42 #1 by nico0Las1
Hello all,
I was on 4.5.2 and just upgrated to 4.5.4 and the problem still exists :
When i want to register a new requirement, I can choose a "Product" from the menu as long as i didn't fill a "Project".
-> If i choose a Project, then i can't select any Product in the menu (empty menu).
If i delete the project name from the menu, I can see again the products in the menu.
Is it a bug, or some parameters that changed ?
It worked good before, i could fill it any order but not anymore.
Thanks !
Last edit: 05 Feb 2015 01:42 by nico0Las1.
05 Feb 2015 09:37 #2 by babynus
It is not a bug, but a fix intoduced in V4.5.
When you select a Project, in the product list you must list only Products linked to the Project.
This means that when you select a project, list of products is restricted to products having at least one version linked to the project.
The following user(s) said Thank You: nico0Las1
16 Feb 2015 23:10 #3 by nico0Las1
Thank you ! I didn't notice before these items were linked together :)
